06-三层技术-IP业务命令参考
05-NAT命令
本章节下载 05-NAT命令  (333.35 KB)
05-NAT命令
1 NAT命令
NAT功能目前仅在独立运行模式下支持。
1.1  NAT配置命令
1.1.1  address
address命令用来添加一个地址组成员。
undo address命令用来删除一个地址组成员。
address start-address end-address
undo address start-address end-address
不存在地址组成员
NAT地址组视图
start-address end-address:地址组成员的起始IP地址和结束IP地址。end-address必须大于或等于start-address,如果start-addressend-address相同,则表示只有一个地址。
一个NAT地址组是多个地址组成员的集合。当需要对到达外部网络的数据报文进行地址转换时,报文的源地址将被转换为地址组成员中的某个地址。
·              一个地址组成员所包含的地址数目不能超过256。
·              各地址组成员的IP地址段不能互相重叠。
# 在NAT地址组2中添加两个地址组成员。
[Sysname] nat address-group 2
[Sysname-nat-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-nat-address-group-2] address 10.1.1.20 10.1.1.30
·              nat address-group
1.1.2  display nat all
display nat all命令用来显示所有的NAT配置信息。
display nat all
#显示所有的NAT配置信息。
<Sysname> display nat all
NAT address group information:
  Totally 5 NAT address groups.
  Address group 1:
    Port range: 1-65535
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
  Address group 2:
    Port range: 1-65535
      202.110.10.20         202.110.10.25
      202.110.10.30         202.110.10.35
  Address group 3:
    Port range: 1024-65535
      202.110.10.40         202.110.10.50
  Address group 4:
    Port range: 10001-65535
    Port block size: 500
    Extended block number: 1
      202.110.10.60         202.110.10.65
  Address group 6:
    Port range: 1-65535
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
NAT inbound information:
  Totally 1 NAT inbound rules.
    ACL: 2038         Address group: 2      Add route: Y
    NO-PAT: Y         Reversible: N
    VPN instance: vpn_nat
    Service card: Slot 2
    Config status: Active
NAT outbound information:
  Totally 2 NAT outbound rules.
    ACL: 2036         Address group: 1      Port-preserved: Y
    NO-PAT: N         Reversible: N
    Service card: ---
    Config status: Inactive
    Reasons for inactive status:
      The following items don't exist or aren't effective: address group, and ACL.
      Service card not specified.
    ACL: 2037         Address group: 1      Port-preserved: N
    NO-PAT: Y         Reversible: Y
    Service card: ---
NAT internal server information:
  Totally 4 internal servers.
  Interface: GigabitEthernet1/0/3
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23
    Local IP/port : 192.168.10.15/23
    ACL           : 2000
    Service card  : Slot 2
    Config status : Active
  Interface: GigabitEthernet1/0/4
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23-30
    Local IP/port : 192.168.10.15-192.168.10.22/23
    Global VPN    : vpn1
    Local VPN     : vpn3
    Protocol: 255(Reserved)
    Global IP/port: 50.1.1.100/---
    Local IP/port : 192.168.10.150/---
    Global VPN    : vpn2
    Local VPN     : vpn4
    ACL           : 3000
    Config status : Inactive
      The following items don't exist or aren't effective: local VPN, and ACL.
  Interface: GigabitEthernet1/0/5
    Protocol: 17(UDP)
    Global IP/port: 50.1.1.2/23
    Local IP/port : server group 1
                    192.168.0.26/23       (Connections: 10)
                    192.168.0.27/23       (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn3
Static NAT mappings:
  Totally 2 inbound static NAT mappings.
  Net-to-net:
    Global IP    : 2.2.2.1 – 2.2.2.255
    Local IP     : 1.1.1.0
    Netmask      : 255.255.255.0
    Global VPN   : vpn2
    Local VPN    : vpn1
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    Global VPN   : vpn3
    Local VPN    : vpn4
    ACL          : 2001
    Reversible   : Y
      The following items don't exist or aren't effective: local VPN, global VPN, and ACL.
  Totally 2 outbound static NAT mappings.
  Net-to-net:
    Local IP     : 1.1.1.1 - 1.1.1.255
    Global IP    : 2.2.2.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL:         : 2001
    Reversible   : Y
      The following items don't exist or aren't effective: ACL.
Interfaces enabled with static NAT:
  Totally 2 interfaces enabled with static NAT.
  Interface: GigabitEthernet1/0/6
    Service card : ---
NAT DNS mappings:
  Totally 2 NAT DNS mappings.
  Domain name  : www.server.com
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Domain name  : www.service.com
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
    The following items don't exist or aren't effective: interface IP address.
NAT logging:
  Log enable          : Enabled(ACL 2000)
  Flow-begin          : Disabled
  Flow-end            : Disabled
  Flow-active         : Enabled(10 minutes)
  Port-block-assign   : Disabled
  Port-block-withdraw : Disabled
  Alarm               : Disabled
NAT hairpinning:
  Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
  Mapping mode : Endpoint-Independent
  ACL          : 2050
NAT ALG:
  DNS        : Enabled
  FTP        : Enabled
  H323       : Enabled
  ICMP-ERROR : Enabled
  ILS        : Enabled
  MGCP       : Enabled
  NBT        : Enabled
  PPTP       : Enabled
  RTSP       : Enabled
  RSH        : Enabled
  SCCP       : Enabled
  SIP        : Enabled
  SQLNET     : Enabled
  TFTP       : Enabled
  XDMCP      : Disabled
上述显示信息是目前所有NAT配置信息的集合。由于部分NAT配置(nat address-groupnat server-groupnat inboundnat outboundnat servernat staticnat static net-to-netnat static enablenat dns-mapnat log)有自己独立的显示命令,且此处显示信息的格式与各命令对应的显示信息的格式相同的,所以此处不对这些配置的显示字段的含义进行写详细解释,如有需要,请参考各独立的显示命令。下面的表格将给出相关显示命令的参见信息并仅解释nat hairpin enablenat mapping-behaviornat alg配置的显示字段的含义。
表1-1 display nat all命令显示信息描述表
NAT地址组的配置信息,详细字段解释请参见“表1-2
NAT内部服务器组的配置信息,详细字段解释请参见“表1-11
入方向动态地址转换的配置信息,详细字段解释请参见“表1-5
出方向动态地址转换的配置信息,详细字段解释请参见“表1-8
NAT内部服务器的配置信息,详细字段解释请参见“表1-10
Static NAT mappings
静态地址转换的配置信息,详细字段解释请参见“表1-14
NAT DNS mappings
NAT DNS mapping的配置信息,详细字段解释请参见“表1-3
NAT logging
NAT日志功能的配置信息,详细字段解释请参见“表1-6
NAT hairpinning
NAT hairpin功能
Totally n interfaces enabled NAT hairpinning
当前有n个接口使能NAT hairpin功能
使能NAT hairpin功能的接口
Service card
显示提供NAT处理的业务板。如果接口下没有指定业务板,则显示为“---”
Config status
显示NAT hairpin配置的状态
·       Active:生效
·       Inactive:不生效
当Config status字段为Inactive时,显示NAT hairpin配置不生效的原因
·       Service card not specified:没有指定提供NAT处理的业务板
PAT方式下的地址转换模式
·       Endpoint-Independent:表示不关心对端地址和端口
·       Address and Port-Dependent:表示关心对端地址和端口
ACL
引用的ACL编号。如果没有配置,则显示“---”
Config status
显示NAT mapping behavior配置的状态
·       Active:生效
·       Inactive:不生效
当Config status字段为Inactive时,显示NAT mapping behavior配置不生效的原因
·       The following items don't exist or aren't effective: ACL:引用的ACL不存在
NAT ALG
各协议的NAT ALG功能开启信息
1.1.3  display nat address-group
display nat address-group命令用来显示NAT地址组配置信息。
display nat address-group [ group-number ]
group-number地址组编号,取值范围为0~max_number。其中max_number的取值范围为0~65535。如果不设置该值,则显示所有地址组。
# 显示所有地址组的配置信息。
<Sysname> display nat address-group
  Address group 1:
    Port range: 1-65535
  Address group 2:
    Port range: 1-65535
  Address group 3:
  Address group 4:
  Address group 6:
    Port range: 1-65535
# 显示指定地址组的配置信息。
<Sysname> display nat address-group 1
  Address group 1:
    Port range: 1-65535
表1-2 display nat address-group命令显示信息描述表
NAT地址组信息
Totally n NAT address groups
当前有n个地址组
Address group
地址组编号
Port range
地址的端口范围
Block size
端口块大小。如果没有配置,则不显示
增量端口块数。如果没有配置,则不显示
Address information
地址组成员信息
Start address
地址组成员的起始地址。如果没有配置,则显示”---”
End address
地址组成员的结束地址。如果没有配置,则显示”---”
·              nat address-group
1.1.4  display nat dns-map
display nat dns-map命令用来显示NAT DNS mapping配置信息。
display nat dns-map
# 显示所有NAT DNS mapping的配置信息。
<Sysname> display nat dns-map
NAT DNS mapping information:
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
表1-3 display nat dns-map命令显示信息描述表
NAT DNS mapping配置信息
Totally n NAT DNS mappings
当前有n条DNS mapping配置
Domain name
DNS域名
Global IP
外网地址。如果配置使用的是Easy IP方式,则此处显示指定的接口的地址。“---”表示接口下没有配置外网地址
Global port
外网端口号
Protocol
协议名称以及协议编号
Config status
显示DNS mapping配置的状态
·       Active:生效
·       Inactive:不生效
当Config status字段为Inactive时,显示DNS mapping配置不生效的原因
·       The following items don't exist or aren't effective: interface IP address:引用的接口没有配置IP地址
·              nat dns-map
1.1.5  display nat eim
display nat eim命令用来显示NAT EIM表项信息。
display nat eim [ slot slot-number ]
slot slot-number:显示指定单板上的EIM表项信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的EIM表项信息。
EIM表项是报文在进行Endpoint-Independent Mapping方式的PAT转换时创建的,它记录了内网和外网的转换关系(内网地址和端口<-->NAT地址和端口),该表项有以下两个作用:
·              保证后续来自相同源地址和源端口的新建连接与首次连接使用相同的转换关系。
·              允许外网主机向NAT地址和端口发起的新建连接根据EIM表项进行反向地址转换。
# 显示1号单板上的NAT EIM表项信息。
<Sysname> display nat eim slot 1
Slot 1:
Local  IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Local  IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
表1-4 display nat eim命令显示信息描述表
Local IP/port
内网IP地址/端口号
Global IP/port
外网IP地址/端口号
Local VPN
内网地址所属的MPLS L3VPN的VPN实例名称。如果不属于任何VPN,则不显示该字段
Global VPN
外网地址所属的MPLS L3VPN的VPN实例名称。如果不属于任何VPN,则不显示该字段
Protocol
协议名称以及协议编号
Total entries found
当前查找到的EIM表项的个数
·              nat mapping-behavior
·              nat outbound
1.1.6  display nat inbound
display nat inbound命令用来显示NAT入方向动态地址转换的配置信息。
display nat inbound
# 显示NAT入接口动态地址转换的配置信息。
<Sysname> display nat inbound
  Totally 2 NAT inbound rules.
    VPN instance: vpn1
    Service card: Slot 5
    ACL: 2037         Address group: 1      Add route: Y
    VPN instance: vpn2
    Service card: ---
表1-5 display nat inbound命令显示信息描述表
NAT入方向动态地址转换的配置信息
Totally n NAT inbound rules
当前存在n条入入方向动态地址转换配置
入方向动态地址转换配置所在的接口
ACL
引用的ACL编号
Address group
入方向动态地址转换使用的地址组
Add route
是否添加路由。若其值为“Y”,则表示有报文命中此项入接口动态地址转换配置时,设备会自动添加一条路由;否则,不添加
NO-PAT
是否使用NO-PAT方式进行地址转换。若其值为“Y”,则表示使用NO-PAT方式;若其值为“N”,则表示使用PAT方式
Reversible
是否允许反向地址转换。若其值为“Y”,则表示在某方向上发起的连接已成功建立地址转换表项的情况下,允许反方向发起的连接使用已建立的地址转换表项进行地址转换;否则,不允许
VPN instance
地址组所属的MPLS L3VPN的VPN实例名称。如果不属于任何VPN,则不显示该字段
Service card
Config status
显示NAT配置的状态
·       Active:生效
·       Inactive:不生效
当Config status字段为Inactive时,显示NAT入方向动态地址转换的配置不生效的原因
·       The following items don't exist or aren't effective: local VPN, and ACL:配置中地址组所属的VPN实例、ACL不存在或不生效
·       Service card not specified:没有指定提供NAT处理业务板
·              nat inbound
1.1.7  display nat log
display nat log命令用来显示NAT日志功能的配置信息。
display nat log
# 显示NAT日志功能的配置信息。
<Sysname> display nat log
NAT logging:
  Flow-end            : Disabled
  Alarm               : Disabled
表1-6 display nat log命令显示信息描述表
NAT logging
NAT日志功能的配置信息
Log enable
NAT日志开关的开启情况。如果NAT日志开关处于开启状态,且指定了ACL,则同时显示指定的ACL编号
Flow-begin
NAT会话新建日志开关的开启情况
Flow-end
NAT会话删除日志开关的开启情况
Flow-active
NAT活跃流日志开关的开启情况以及阈值信息。如果NAT活跃流日志开关处于开启状态,则同时显示配置的生成活跃流日志的时间间隔(单位为分)
Port-block-assign
端口块分配的NAT444用户日志开关的开启情况
Port-block-withdraw
端口块回收的NAT444用户日志开关的开启情况
Alarm
NAT444告警信息日志开关的开启情况
·              nat log enable
·              nat log flow-active
·              nat log flow-begin
1.1.8  display nat no-pat
display nat no-pat命令用来显示NAT NO-PAT表项信息。
display nat no-pat [ slot slot-number ]
slot slot-number:显示指定单板上的NO-PAT表项信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的NO-PAT表项信息。
NO-PAT表项记录了动态分配的一对一地址映射关系,该表项有两个作用:
·              保证后续同方向的新连接使用与第一个连接相同的地址转换关系。
·              反方向的新连接可以使用NO-PAT表进行地址转换。
nat inboundnat outbound配置的NO-PAT方式在转换报文地址之后都需要创建NO-PAT表。这两种配置创建的NO-PAT表类型不同,不能互相使用,因此分成两类进行显示。
# 显示1号单板上的NAT NO-PAT表项。
<Sysname> display nat no-pat slot 1
Slot 1:
Global  IP: 200.100.1.100
Local   IP: 192.168.100.100
Global VPN: vpn2
Local  VPN: vpn1
Reversible: N
Type      : Inbound
Local   IP: 192.168.100.200
Global  IP: 200.100.1.200
Reversible: Y
Type      : Outbound
表1-7 display nat no-pat命令显示信息描述表
Local IP
内网IP地址
Global IP
外网IP地址
Local VPN
内网地址所属的MPLS L3VPN的实例名称。如果不属于任何VPN,则该行不显示
Global VPN
外网地址所属的MPLS L3VPN的实例名称。如果不属于任何VPN,则该行不显示
Reversible
NO-PAT表项类型
Inbound:入方向动态地址转换过程中创建的NO-PAT表项
Outbound:出方向动态地址转换过程中创建的NO-PAT表项
Total entries found
当前查找到的NO-PAT表项的个数
·              nat inbound
·              nat outbound
1.1.9  display nat outbound
display nat outbound命令用来显示出方向动态地址转换的配置信息。
# 显示出方向动态地址转换的配置信息。
<Sysname> display nat outbound
    ACL: 2037         Address group: 2      Port-preserved: N
      The following items don't exist or aren't effective: global VPN, and ACL.
表1-8 display nat outbound命令显示信息描述表
出方向动态地址转换的配置信息
Totally n NAT outbound rules
当前存在n条出方向动态地址转换
出方向动态地址转换配置所在的接口
ACL
Address group
出方向动态地址转换使用的地址组。如果没有配置,则显示“---
Port-preserved
PAT方式下,是否尽量不转换端口
NO-PAT
是否使用NO-PAT方式进行转换。若其值为“N”,则表示使用PAT方式
Reversible
VPN instance
Service card
Config status
显示配置的状态
·       Active:生效
·       Inactive:不生效
当Config status字段为Inactive时,显示配置不生效的原因
·       The following items don't exist or aren't effective: global VPN and ACL:配置中地址组所属的VPN实例、ACL不存在或不生效
·       NAT address conflicts:NAT地址冲突
·              nat outbound
1.1.10  display nat port-block dynamic
display nat port-block dynamic命令用来显示动态端口块表项。
display nat port-block dynamic [ slot slot-number ]
slot slot-number:显示指定单板上的端口块表项信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的端口块表项信息。
# 显示动态端口块表项。
<Sysname> display nat port-block dynamic
Local VPN     Local IP         Global IP        Port block   Connections
---           101.1.1.12       192.168.135.201  10001-11024  1
Total entries found: 1
表1-9 display nat port-block 命令显示信息描述表
Local VPN
私网IP地址所属VPN,“---”表示不属于任何VPN
Local IP
私网IP地址
Global IP
公网IP地址
Port block
端口块(起始端口-结束端口)
Connections
当前使用本端口块中的端口建立的连接数
1.1.11  display nat server
display nat server命令用来显示NAT内部服务器的配置信息。
display nat server
# 显示NAT内部服务器的信息。
<Sysname> display nat server
    Protocol: 6(TCP)
    Service card  : ---
    Protocol: 6(TCP)
    Global VPN    : vpn1
    Local VPN     : vpn3
    Service card  : ---
      The following items don't exist or aren't effective: local VPN.
    Global VPN    : vpn2
    Local VPN     : vpn4
    Service card  : Slot 5
    Protocol: 17(UDP)
                    1.1.1.1/21            (Connections: 10)
                    192.168.100.200/80    (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn10
表1-10 display nat server命令显示信息描述表
NAT内部服务器的配置信息
Totally n internal servers
当前存在n条内部服务器配置
内部服务器配置所在的接口
Protocol
内部服务器的协议编号以及协议名称
Global IP/port
内部服务器的外网地址/端口号
·       Global IP可以是单个地址,也可以是一个连续的地址段。如果使用Easy IP方式,则此处显示指定的接口的地址;如果接口下没有配置地址,则Global IP显示为“---”
·       port可以是单个端口,也可以是一个连续的端口段。如果指定的协议没有端口的概念,则port显示为“---”
Local IP/port
对于普通内部服务器,显示服务器的内网地址/端口号
·       Local IP可以是单个地址,也可以是一个连续的地址段
对于负载分担内部服务器,显示内部服务器组编号以及服务器组成员的IP地址、端口和连接数
Global VPN
Local VPN
内网地址所属的MPLS L3VPN的VPN实例名称。 如果不属于任何VPN,则不显示该字段
ACL
引用的ACL编号。如果没有配置,则不显示该字段
Service card
Config status
显示配置的状态
·       Active:生效
·       Inactive:不生效
·       The following items don't exist or aren't effective: local VPN, global VPN, interface IP address, server group, and ACL:配置中内网地址所属的VPN实例、外网地址所属的VPN实例、接口地址、服务器组、ACL不存在或不生效
·       Server configuration conflicts:NAT内部服务器配置冲突
·              nat server
1.1.12  display nat server-group
display nat server-group命令用来显示NAT内部服务器组的配置信息。
display nat server-group [ group-number ]
group-number:NAT内部服务器组编号,取值范围为0~65535。
# 显示所有NAT内部服务器组的配置信息。
<Sysname> display nat server-group
                      192.168.0.27          23          500
  2                   ---                   ---         ---
# 显示指定NAT内部服务器组的配置信息。
<Sysname> display nat server-group 1
                      192.168.0.27          23          500
表1-11 display nat server-group命令显示信息描述表
NAT内部服务器组信息
Totally n NAT server groups
当前有n个内部服务器组
Group Number
内部服务器组编号
Inside IP
内部服务器组成员在内网的IP地址。如果没有配置,则显示“---”
Port
内部服务器组成员在内网的端口。如果没有配置,则显示“---
Weight
内部服务器组成员的权重值。如果没有配置,则显示“---
·              nat server-group
1.1.13  display nat service slot
display nat service slot命令用来显示指定单板上NAT地址转换的统计信息。
display nat service slot slot-number
# 显示2号单板上NAT地址转换的统计信息。
<Sysname>display nat service slot 2
- NAT SERVICE CALCULATION        Slot 2
input packet of each VCPU:
        0             0             0             0
        0             0             0             0
   161434        161434        159882        159882
   144359        144358        144358        144359
 output packet of each VCPU:
        0             0             0             0
        0             0             0             0
 Input  packet count: total 1862698         error 0
 Output packet count: total 1862698         error 0
表1-12 display interface命令显示信息描述表
指定提供NAT处理的业务板
每个物理核收到的NAT报文总数
四行数据:表示四个物理核
四列数据:表示每个物理核分为四个VCPU,以及每个VCPU收到的NAT报文总数
第一行表示主核,不进行数据业务报文处理,所以每个VCPU收到的报文数均为0;后面两行表示进行数据业务报文处理的物理核
NAT Output packet of each VCPU
每个物理核发送的NAT报文总数
四行数据:表示四个物理核
四列数据:表示每个物理核分为四个VCPU,以及每个VCPU发送的NAT报文总数
第一行表示主核,不进行数据业务报文处理,所以每个VCPU发送的报文数均为0;后面两行表示进行数据业务报文处理的物理核
NAT input  packet count
接收的NAT报文总数
NAT Output packet count
发送的NAT报文总数
1.1.14  display nat session
display nat session命令用来显示NAT会话,即经过NAT地址转换处理的会话。
display nat session [ { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn -name ] ] [ slot slot-number ] [ verbose ]
source-ip source-ip:显示指定源地址的会话。source-ip表示源地址,该地址必须是创建会话的报文的源地址。
destination-ip destination-ip:显示指定目的地址的会话。destination-ip表示目的地址,该地址必须是创建会话的报文的目的地址。
vpn-instance vpn-name:显示指定目的VPN的会话。vpn-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。该VPN必须是报文中携带的VPN。如果不指定该参数,则显示目的IP不属于任何VPN的会话。
slot slot-number:显示指定单板上的NAT会话,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有单板上的NAT会话。
verbose:显示NAT会话的详细信息。如果不配置则显示会话的概要信息。
如果不指定任何参数,则显示所有的NAT会话。
# 显示1号单板上NAT会话的详细信息。
<Sysname> display nat session verbose slot 1
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: TCP(6)
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.18/1877
  Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36  TTL: 28s
Interface(in) : GigabitEthernet1/0/1
Interface(out): GigabitEthernet1/0/2
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Total sessions found: 1
表1-13 display nat session命令显示信息描述表
Initiator
发起方的会话信息
Responder
响应方的会话信息
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
Protocol
传输层协议类型,包括:DCCP、ICMP、Raw IP 、SCTP、TCP、UDP、UDP-Lite
会话所属的MPLS L3VPN/二层转发时会话所属的VLAN ID/二层转发时会话所属的INLINE。如果未指定则显示“-/-/-”
会话状态
Application
应用层协议类型,包括:FTP、DNS等,unknown表示非知名端口对应的协议类型
Start time
会话创建时间
TTL
会话剩余存活时间,单位为秒
Interface(in)
入接口
Interface(out)
出接口
发起方到响应方的报文数、报文字节数
响应方到发起方的报文数、报文字节数
当前查找到的会话表总数
·              reset nat session
1.1.15  display nat static
display nat static命令用来显示NAT静态地址转换的配置信息。
display nat static
# 显示NAT静态地址转换的配置信息。
<Sysname> display nat static
  Net-to-net:
    Global IP    : 1.1.1.1 - 1.1.1.255
    Local IP     : 2.2.2.0
    Global VPN   : vpn2
    Local VPN    : vpn1
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Global IP   : 5.5.5.5
    Local IP     : 4.4.4.4
    Global VPN   : vpn3
    Local VPN    : vpn4
    ACL          : 2001
    Reversible   : Y
  Net-to-net:
    Global IP    : 2.2.2.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn4
    Global VPN   : vpn3
    ACL:         : 2000
    Reversible   : Y
      The following items don't exist or aren't effective: local VPN, and global VPN.
    Service card : ---
表1-14 display nat static命令显示信息描述表
Static NAT mappings
静态地址转换的配置信息
Totally n inbound static NAT mappings
当前存在n条入方向静态地址转换的配置
Totally n outbound static NAT mappings
当前存在n条出方向静态地址转换的配置
Net-to-net
网段到网段的静态地址转换映射
IP-to-IP
IP到IP的静态地址转换映射
Local IP
内网IP地址或地址范围
Global IP
外网IP地址或地址范围
Netmask
IP地址掩码
Local VPN
Global VPN
ACL
Reversible
如果没有配置,则不显示该字段
静态地址转换在接口下的使能情况
Totally n interfaces enabled with static NAT
当前有n个接口使能了静态地址转换
使能静态地址转换功能的接口
Service card
显示提供NAT服务的业务板。如果接口下没有指定业务板,则显示为“---”
Config status
显示配置的状态
·       Active:生效
·       Inactive:不生效
·       The following items don't exist or aren't effective: local VPN, global VPN, and ACL:配置中内网地址所属的VPN实例、外网地址所属的VPN实例、ACL不存在或不存在
·       Service card not specified:没有指定提供NAT服务的业务板
·              nat static
·              nat static net-to-net
·              nat static enable
1.1.16  display nat statistics
display nat statistics命令用来显示NAT统计信息。
display nat statistics [ slot slot-number ]
slot slot-number:显示指定单板上的NAT统计信息,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有单板上的NAT统计信息。
# 显示所有NAT统计信息。
<Sysname> display nat statistics
  Total session entries count: 100
  Total EIM entries count: 1
  Total inbound NO-PAT entries count: 0
  Total outbound NO-PAT entries count: 0
  Total dynamic port block entries: 15
  Active dynamic port block entries: 0
表1-15 display nat statistics命令显示信息描述表
NAT会话表项个数
EIM表项个数
入方向的NO-PAT表项个数
出方向的NO-PAT表项个数
当前配置可创建的动态端口块表项个数,即可分配的动态端口块总数,包括已分配的端口块和尚未分配的端口块
当前已创建的动态端口块表项个数,即已分配的动态端口块个数
1.1.17  inside ip
inside ip命令用来添加一个内部服务器组成员。
undo inside ip命令用来删除一个内部服务器组成员。
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
内部服务器组内没有内部服务器组成员。
内部服务器组视图
inside-ip:内部服务器组成员的IP地址。
port port-number:内部服务器组成员提供服务的端口号,取值范围为165535
weight weight-value:内部服务器组成员的权重。weight-value表示权值,取值范围为11000,缺省为100
内部服务器组成员按照权重比例对外提供服务,权重值越大的内部服务器组成员对外提供服务的比重越大。
# 为内部服务器组1添加一个内部服务器组成员,其IP地址为10.1.1.2,服务端口号为30。
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
·              nat server-group
1.1.18  nat address-group
nat address-group命令用来创建一个地址组,并进入地址组视图。
undo nat address-group命令用来删除指定的地址组。
nat address-group group-number
undo nat address-group group-number
不存在地址组
group-number:地址组编号,取值范围为0~max_number。其中max_number的取值范围为0~65535。
一个地址组是多个地址组成员的集合,各个地址组成员通过address命令配置。当需要对数据报文进行动态地址转换时,其源地址将被转换为地址组成员中的某个地址。
# 创建一个地址组,编号为1。
[Sysname] nat address-group 1
·              address
·              display nat address-group
·              display nat all
·              nat inbound
·              nat outbound
1.1.19  nat alg
nat alg命令用来开启指定或所有协议类型的NAT ALG功能。
undo nat alg命令用来关闭指定或所有协议类型的NAT ALG功能。
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
所有协议类型的NAT ALG功能均处于开启状态。
all:所有可指定的协议的ALG功能。
dns:表示DNS协议的ALG功能。
ftp:表示FTP协议的ALG功能。
h323:表示H323协议的ALG功能。
icmp-error:表示ICMP差错控制报文的ALG功能。
ils:表示ILS(Internet Locator Service,互联网定位服务)协议的ALG功能。
mgcp:表示MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议的ALG功能。
nbt:表示NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议的ALG功能。
pptp:表示PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议的ALG功能。
rsh:表示RSH(Remote Shell,远程外壳)协议的ALG功能。
rtsp:表示RTSPReal Time Streaming Protocol,实时流协议)协议的ALG功能。
sccp:表示SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议的ALG功能。
sip:表示SIPSession Iniation Protocol,会话初始协议)协议的ALG功能。
sqlnet:表示SQLNET协议的ALG功能。
tftp:表示TFTP协议的ALG功能。
xdmcp:表示XDMCP(X Display Manager Control Protocol,X显示监控)协议的ALG功能。
ALG(Application Level Gateway,应用层网关)主要完成对应用层报文的解析和处理。通常情况下,NAT只对报文头中的IP地址和端口信息进行转换,不对应用层数据载荷中的字段进行分析和处理。然而对于一些应用层协议,它们的报文的数据载荷中可能包含IP地址或端口信息,这些载荷信息也必须进行有效的转换,否则可能导致功能不正常。
例如,FTP应用由数据连接和控制连接共同完成,而数据连接使用的地址和端口由控制连接协商报文中的载荷信息决定,这就需要ALG利用NAT的相关转换配置来完成载荷信息的转换,以保证后续数据连接的正确建立。
# 开启FTP协议的ALG功能。
[Sysname] nat alg ftp
·              display nat all
1.1.20  nat dns-map
nat dns-map命令用来配置一条域名到内部服务器的映射。
undo nat dns-map命令用来删除一条域名到内部服务器的映射。
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
不存在域名到内部服务器的映射。
domain domain-name:指定内部服务器的合法域名。domain-name表示内部服务器的域名,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”。
protocol pro-type:指定内部服务器的协议类型。pro-type表示具体的协议类型,取值为tcpudp
interface interface-type interface-number:表示使用指定接口的地址作为内部服务器的外网地址。interface-type interface-number表示接口类型和接口编号。
ip global-ip:指定内部服务器提供给外部网络访问的IP地址。global-ip表示外网IP地址。
port global-port:指定内部服务器提供给外部网络访问的服务端口号,可输入的形式如下:
·              数字:取值范围为1~65535。
·              协议名称:为1~15个字符的字符串,例如ftptelnet等。
NAT的DNS mapping功能需要和内部服务器配合使用,主要应用于DNS服务器在外网,应用服务器在内网(在NAT设备上有对应的nat server配置),内网用户需要通过域名访问内网应用服务器的场景。NAT设备对来自外网的DNS响应报文进行DNS ALG处理时,由于载荷中只包含域名和应用服务器的外网IP地址(不包含传输协议类型和端口号),当接口上存在多条NAT服务器配置且使用相同的外网地址而内网地址不同时,DNS ALG仅使用IP地址来匹配内部服务器可能会得到错误的匹配结果。因此需要借助DNS mapping的配置,指定域名与应用服务器的外网IP地址、端口和协议的映射关系,由域名获取应用服务器的外网IP地址、端口和协议,进而(在当前NAT接口上)精确匹配内部服务器配置获取应用服务器的内网IP地址。
设备可支持配置多条域名到内部服务器的映射。
# 某公司内部对外提供Web服务,内部服务器的域名为www.server.com,对外的IP地址为202.112.0.1,服务端口号为12345。配置一条域名到内部服务器的映射,使得公司内部用户可以通过域名访问内部Web服务器。
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port 12345
·              display nat all
·              display nat dns-map
·              nat server
1.1.21  nat hairpin enable
nat hairpin enable命令用来使能NAT hairpin功能。
undo nat hairpin enable用来关闭NAT hairpin功能。
nat hairpin enable
NAT hairpin功能处于关闭状态。
NAT hairpin功能用于满足位于内网侧的用户之间或用户与服务器之间通过NAT地址进行访问的需求,需要与内部服务器(nat server)、出方向动态地址转换(nat outbound)或出方向静态地址转换(nat static outbound)配合工作。使能NAT hairpin的内网侧接口上会对报文同时进行源地址和目的地址的转换。
# 在GigabitEthernet1/0/1接口下开启NAT hairpin功能。
[Sysname-GigabitEthernet1/0/1] nat hairpin enable
·              display nat all
1.1.22  nat inbound
nat inbound命令用来配置入方向动态地址转换。
undo nat inbound命令用来删除指定的入方向动态地址转换。
nat inbound acl-number address-group group-number [ vpn-instance vpn-instance-name ] [ no-pat [ reversible ] [ add-route ] ]
undo nat inbound acl-number
不存在入方向动态地址转换配置。
acl-number:ACL编号,取值范围为2000~3999。
address-group group-number:指定地址转换使用的地址组。group-number为地址组编号,取值范围为0~65535。
vpn-instance vpn-instance-name:指定地址组中的地址所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示地址组中的地址不属于任何一个VPN。
no-pat:表示使用NO-PAT方式进行转换,即转换时不使用报文的端口信息。如果未指定本参数,则表示使用PAT方式进行转换,即转换时使用报文的端口信息。PAT方式仅支持TCP、UDP和ICMP查询报文,由于ICMP报文没有端口的概念,我们将ICMP ID作为ICMP报文的源端口。
reversible:表示允许反向地址转换。即,在外网用户主动向内网发起连接并成功触发建立地址转换表项的情况下,允许内网向该外网用户发起的连接使用已建立的地址转换表项进行目的地址转换。
add-route:为转换后的地址添加路由表,其目的地址是转换后的地址,出接口为进行地址转换的接口,下一跳为该报文转换前的源地址。
从配置了入方向地址转换的接口接收到的符合ACL permit规则的报文,会使用地址组group-number中的地址进行源地址转换。
入方向地址转换有两种转换方式:
·              PAT方式:对于从外网到内网的报文,如果符合ACL,则使用地址组中的地址进行源地址转换,同时转换源端口(IP1/port1转换为IP2/port2)。
·              NO-PAT方式:对于从外网到内网的报文,如果符合ACL,则使用地址组中的地址进行源地址转换,不转换源端口(IP1转换为IP2);如果用户配置了reversible,则允许内网通过IP2主动访问外网,对于此类访问报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并将目的地址转换为IP1,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能进行转换(将目的地址IP2转换为IP1),否则不予转换。
nat inbound命令通常与nat outboundnat servernat static配合使用,用于支持在外网侧口上对报文同时进行源和目的转换,即双向NAT。
·              一个地址组被nat inbound配置引用后,就不能再被nat outbound配置引用。
·              一个地址组被PAT方式的nat inbound配置引用后,不能再被NO-PAT方式的nat inbound配置引用,反之亦然。
·              在一个接口下,一个ACL只能被一个nat inbound引用。
·              add-route参数不能应用在内外与外网地址重叠的组网场景中。
·              如果指定了add-route参数,则有报文命中该配置时,设备会自动添加路由表项:目的地址为本次地址转换使用的地址组中的地址,出接口为本配置所在接口,下一跳地址为报文的源地址;如果没有指定add-route参数,则用户需要在设备上手工添加路由。由于自动添加路由表项速度较慢,通常建议手工添加路由。
·              一个接口下可同时配置多条入方向地址转换。
# 配置ACL 2001,允许对10.110.10.0/24网段的主机进行地址转换。
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-basic-2001] rule deny
[Sysname-acl-basic-2001] quit
# 配置地址组1,并添加地址组成员:202.110.10.10、202.110.10.11、202.110.10.12。
[Sysname-nat-address-group-1] address 202.110.10.10 202.110.10.12
# 在接口GigabitEthernet1/0/1上配置入方向动态地址转换,使用地址组1中的地址进行地址转换,在转换的时候不使用TCP/UDP的端口信息,且需要添加路由。
[Sysname-GigabitEthernet1/0/1] nat inbound 2001 address-group 1 no-pat add-route
·              display nat all
·              display nat inbound
·              display nat no-pat
1.1.23  nat log alarm
nat log alarm命令用来开启NAT444告警信息日志功能。
undo nat log alarm命令用来关闭NAT444告警信息日志功能。
nat log alarm
undo nat log alarm
NAT444告警信息日志功能处于关闭状态。
在NAT444地址转换中,如果可为用户分配的公网IP地址、端口块或端口块中的端口都被占用,则该用户的后续连接由于没有可用的资源无法对其进行地址转换,相应的报文将被丢弃。为了监控公网IP地址和端口块资源的使用情况,可以通过开启NAT444告警信息日志功能来对端口用满和资源用满两种情况记录告警信息日志。
·              端口用满告警:在私网IP地址对应的端口块中的所有端口都被占用的情况下,输出告警信息日志。对于端口块动态映射方式,如果配置了增量端口块分配,则当首次分配的端口块中的端口都被占用时,并不输出日志;只有当增量端口块中的端口也都被占用时,才会输出日志。
·              资源用满告警:在NAT444端口块动态映射中,如果所有资源(公网IP地址、端口块)都被占用,则输出日志。
只有开启NAT日志功能之后,NAT444告警信息日志功能才能生效。
# 开启NAT444告警信息日志功能。
[Sysname] nat log alarm
·              display nat all
·              display nat log
·              nat log enable
1.1.24  nat log enable
nat log enable命令用来开启NAT日志功能。
undo nat log enable用来关闭NAT日志功能。
nat log enable [ acl acl-number ]
undo nat log enable
NAT日志功能处于关闭状态。
acl acl-number:指定ACL编号,取值范围为2000~3999。
NAT日志是为了满足网络管理员安全审计的需要,对NAT会话(报文经过设备时,源或目的信息被NAT进行过转换的连接)信息进行的记录,包括用户IP地址和端口的转换信息、用户的访问信息、用户的网络流量信息。
如果指定了acl参数,则只有符合ACL permit规则的数据流才出发输出NAT日志;如果没有指定ACL,则表示对所有被NAT处理过的数据流都有可能出发输出NAT日志。
# 开启NAT日志功能。
[Sysname] nat log enable
·              display nat all
·              display nat log
·              nat log flow-end
1.1.25  nat log flow-active
nat log flow-active命令用来开启NAT活跃流日志功能,并设置生成活跃流日志的时间间隔。
undo nat log flow-active命令用来关闭NAT活跃流的日志功能。
nat log flow-active time-value
NAT活跃流的日志功能处于关闭状态。
time-value:表示触发输出NAT活跃流日志的时间间隔,取值范围为10~120,单位为分钟。
对于一些长时间没有断开的NAT会话(即活跃流),如果需要定期记录其连接情况,则可以通过活跃流日志功能来实现。
开启NAT活跃流日志功能后,对于NAT活跃流,每经过指定的时间间隔,设备就会记录一次NAT日志。
需要注意的是,只有开启NAT日志功能之后,活跃流日志功能才能生效。
# 开启NAT活跃流日志功能,并设置输出NAT活跃流日志的时间间隔为10分钟。
[Sysname] nat log flow-active 10
·              display nat all
·              display nat log
·              nat log enable
1.1.26  nat log flow-begin
nat log flow-begin命令用来开启NAT新建会话的日志功能,即新建NAT会话时,输出NAT日志。
undo nat log flow-begin命令用来关闭NAT新建会话的日志功能。
nat log flow-begin
NAT新建会话的日志功能处于关闭状态。
只有开启NAT日志功能之后,NAT新建会话的日志功能才能生效。
# 开启NAT新建会话的日志功能。
[Sysname] nat log flow-begin
·              display nat all
·              display nat log
·              nat log enable
1.1.27  nat log flow-end
nat log flow-end命令用来开启NAT删除会话的日志功能。
undo nat log flow-end命令用来关闭NAT删除会话的日志功能。
nat log flow-end
NAT删除会话的日志功能处于关闭状态。
只有开启NAT日志功能之后,NAT删除会话的日志功能才能生效。
# 开启NAT删除会话的日志功能。
[Sysname] nat log flow-end
·              display nat all
·              display nat log
·              nat log enable
1.1.28  nat log port-block-assign
nat log port-block-assign命令用来开启端口块分配的NAT444用户日志功能。
undo nat log port-block-assign命令用来关闭端口块分配的NAT444用户日志功能。
端口块分配的NAT444用户日志功能处于关闭状态。
端口块动态映射方式下,在为某私网IP地址分配端口块或增量端口块时,如果开启了端口块分配的NAT444用户日志功能,则会输出日志。
只有开启NAT日志功能之后,端口块分配的NAT444用户日志功能才能生效。
# 开启端口块分配的NAT444用户日志功能。
[Sysname] nat log port-block-assign
·              display nat all
·              display nat log
·              nat log enable
1.1.29  nat log port-block-withdraw
nat log port-block-withdraw命令用来开启端口块回收的NAT444用户日志功能。
undo nat log port-block-withdraw命令用来关闭端口块回收的NAT444用户日志功能。
端口块回收的NAT444用户日志功能处于关闭状态。
端口块动态映射方式下,在释放端口块资源(并删除端口块表项)时,如果开启了端口块回收的NAT444用户日志功能,则会输出日志。
只有开启NAT日志功能之后,端口块回收的NAT444用户日志功能才能生效。
# 开启端口块回收的NAT444用户日志功能。
[Sysname] nat log port-block-withdraw
·              display nat all
·              display nat log
·              nat log enable
1.1.30  nat mapping-behavior
nat mapping-behavior命令用来配置PAT方式出方向动态地址转换的模式。
undo nat mapping-behavior命令用来恢复缺省情况。
nat mapping-behavior endpoint-independent [ acl acl-number ]
undo nat mapping-behavior endpoint-independent
PAT出方向动态方式地址转换的模式为Address and Port-Dependent Mapping。
acl acl-number:指定ACL编号,用于控制需要遵守指定地址转换模式的报文范围。acl-number的取值范围为2000~3999。
PAT方式出方向动态地址转换支持两种模式:
·              Endpoint-Independent Mapping(不关心对端地址和端口的转换模式):只要是来自相同源地址和源端口号的报文,不论其目的地址是否相同,通过PAT映射后,其源地址和源端口号都被转换为同一个外部地址和端口号,该映射关系会被记录下来并生成一个EIM表项;并且NAT网关设备允许外部网络的主机通过该转换后的地址和端口来访问这些内部网络的主机。这种模式可以很好的支持位于不同NAT网关之后的主机间进行互访。
·              Address and Port-Dependent Mapping(关心对端地址和端口的转换模式):对于来自相同源地址和源端口号的报文,若其目的地址和目的端口号不同,由于相同的源地址和源端口号不要求被转换为相同的外部地址和端口号,所以通过PAT映射后,相同的源地址和源端口号通常会被转换成不同的外部地址和端口号。并且NAT网关设备只允许这些目的地址对应的外部网络的主机才可以通过该转换后的地址和端口来访问这些内部网络的主机。这种模式安全性好,但是不便于位于不同NAT网关之后的主机间进行互访。
·              该配置只对出方向动态地址转换的PAT方式起作用。入方向动态地址转换的PAT方式的转换模式始终为 Address and Port-Dependent Mapping。
·              如果配置了acl参数,则表示只有符合ACL permit规则的报文才采用Endpoint-Independent Mapping模式进行地址转换;如果没有配置acl参数,则表示所有的报文都采用Endpoint-Independent Mapping模式进行地址转换。
# 对所有报文都以Endpoint-Independent Mapping模式进行地址转换。
[Sysname] nat mapping-behavior endpoint-independent
# 仅对FTP和HTTP报文才以Endpoint-Independent Mapping模式进行地址转换,其它报文采用Address and Port-Dependent Mapping模式进行地址转换。
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-adv-3000] rule permit tcp destination-port eq 21
[Sysname-acl-adv-3000] quit
[Sysname] nat mapping-behavior endpoint-independent acl 3000
·              nat outbound
·              display nat eim
1.1.31  nat outbound
nat outbound命令用来配置出方向动态地址转换。
undo nat outbound命令用来删除指定的出方向动态地址转换。
不存在动态地址转换配置。
·              NO-PAT方式
nat outbound [ acl-number ] address-group group-number [ vpn-instance vpn-instance-name ] no-pat [ reversible ]
undo nat outbound [ acl-number ]
·              PAT方式
nat outbound [ acl-number ] [ address-group group-number ] [ vpn-instance vpn-instance-name ] [ port-preserved ]
acl-number:ACL编号,取值范围为2000~3999。不指定该参数的情况下,不对转换对象进行限制。
address-group group-number:指定地址转换使用的地址组。group-number为地址组编号,取值范围为0~65535。如果不指定该参数,则直接使用该接口的IP地址作为转换后的地址,即实现Easy IP功能。
vpn-instance vpn-instance-name:指定地址组中的地址所属的VPN。vpn-instance-name表示MPLS L3VPN中的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示地址组中的地址不属于任何一个VPN。
no-pat:表示使用NO-PAT方式进行转换,即转换时不使用报文的端口信息;如果未指定本参数,则表示使用PAT方式进行转换,即转换时使用报文的端口信息。PAT方式仅支持TCP、UDP和ICMP查询报文,由于ICMP报文没有端口的概念,我们将ICMP ID作为ICMP报文的源端口。
reversible:表示允许反向地址转换。即,在内网用户主动向外网发起连接并成功触发建立地址转换表项的情况下,允许外网向该内网用户发起的连接使用已建立的地址转换表项进行目的地址转换。
port-preservedPAT方式分配端口时尽量不转换端口。
一般情况下,出方向动态地址转换配置在和外部网络连接的接口上。动态地址转换有两种转换方式:
·              PAT方式:对于从内网到外网的报文,如果符合ACL permit规则,则使用地址组中的地址或该接口的地址(Easy IP方式)进行源地址转换,同时转换源端口(IP1/port1转换为IP2/port2);如果同时配置了PAT方式下的地址转换模式为EIM(Endpoint-Independent Mapping),则外网可以通过IP2/port2主动访问内网,NAT设备根据EIM表项转换目的地址和端口(IP2/port2转换为IP1/port1)。
·              NO-PAT方式:对于从内网到外网的报文,如果符合ACL permit规则,则使用地址组中的地址进行源地址转换,不转换源端口(IP1转换为IP2);如果同时配置了reversible,则允许外网通过IP2主动访问内网,对于此类报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并将目的地址转换为IP1,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能进行转换(将目的地址IP2转换为IP1),否则不予转换。
·              一个地址组被nat outbound配置引用后,不能再被nat inbound引用。
·              一个地址组被PAT方式的nat outbound配置引用后,不能再被NO-PAT方式的nat outbound配置引用,反之亦然。
·              在一个接口下,一个ACL只能被一个nat outbound引用。
·              一个接口下可同时配置多条出方向地址转换。
·              对于同一接口下的出方向动态地址转换配置,指定了ACL的配置的优先级高于未指定ACL的配置的优先级;对于指定了ACL的出方向动态地址转换配置,其生效优先级由ACL编号的大小决定,编号越大,优先级越高。
# 配置ACL 2001,允许对10.110.10.0/24网段的主机报文进行地址转换。
# 在接口GigabitEthernet1/0/1上配置出方向动态地址转换,允许对匹配ACL 2001的报文使用地址组1中的地址进行地址转换,且在转换的时候使用TCP/UDP的端口信息。
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1
# 如果在接口GigabitEthernet1/0/1上不使用TCP/UDP的端口信息进行地址转换,可以使用如下配置。
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1 no-pat
# 如果直接使用接口GigabitEthernet1/0/1接口的IP地址进行地址转换,可以使用如下的配置。
[Sysname-GigabitEthernet 1/0/1] nat outbound 2001
# 内网10.110.10.0/24网段的主机使用地址组1中的地址作为转换后的地址访问外部网络。如果要在内网用户向外网主动发起访问之后,允许外网用户主动向10.110.10.0/24网段的主机发起访问,并利用已建立的地址转换表项进行反向地址转换,可以使用如下配置。
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1 no-pat reversible
·              display nat eim
·              display nat outbound
1.1.32  nat server
nat server命令用来配置NAT内部服务器,即定义内部服务器的外网地址和端口与内网地址和端口的映射表项。
undo nat server命令用来删除指定的内部服务器配置。
(1)      普通内部服务器
·              外网地址单一,未使用外网端口或外网端口单一
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-name ] inside local-address [ local-port ] [ vpn-instance local-name ] [ acl acl-number ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-name ]
·              外网地址单一,外网端口连续
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-name ] [ acl acl-number ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-name ]
·              外网地址连续,未使用外网端口或外网端口单一
nat server protocol pro-type global global-address1 global-address2  [ global-port ] [ vpn-instance global-name ] inside { local-address | local-address1 local-address2 }  [ local-port ] [ vpn-instance local-name ] [ acl acl-number ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-name ]
·              外网地址连续,外网端口单一
nat server protocol pro-type global global-address1 global-address2  global-port [ vpn-instance global-name ] inside local-address local-port1 local-port2 [ vpn-instance local-name ] [ acl acl-number ]
undo nat server protocol pro-type global global-address1 global-address2  global-port [ vpn-instance global-name ]
(2)      负载均衡内部服务器
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-name ] inside server-group group-number [ vpn-instance local-name ] [ acl acl-number ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-name ]
不存在内部服务器。
protocol pro-type:指定协议类型。当协议类型不是TCP、UDP协议时,配置的内部服务器不带端口参数。pro-type可输入以下形式:
·              数字:取值范围为1~255。
·              协议名称:取值包括icmptcpudp
global-address:内部服务器向外提供服务时对外公布的外网IP地址。
global-address1、global-address2:外网IP地址范围,所包含的地址数目不能超过255global-address1表示起始地址,global-address2表示结束地址。global-address2必须大于global-address1
current-interface:使用当前接口的地址作为内部服务器的外网地址,即实现Easy IP方式的内部服务器。
interface interface-type interface-number:表示使用指定接口的地址作为内部服务器的外网地址,即实现Easy IP方式的内部服务器。interface-type interface-number表示接口类型和接口编号。目前只支持Loopback接口。
global-port1、global-port2:外网端口范围,和内部主机的IP地址范围构成一一对应的关系。global-port1表示起始端口,global-port2表示结束端口。global-port2必须大于global-port1,且端口范围中的端口数目不能大于255。外网端口可输入以下形式:
·              数字:取值范围为1~65535。起始端口和结束端口均支持此形式。
·              协议名称:为1~15个字符的字符串,例如httptelnet等。仅起始端口支持该形式。
local-address1local-address2:定义一组连续的内网IP地址范围,和外网端口范围构成一一对应的关系。local-address1表示起始地址,local-address2表示结束地址。local-address2必须大于local-address1。该地址范围的数量必须和global-port1global-port2定义的端口数量相同。
local-port:内部服务器的内网端口号,可输入以下形式:
·              数字:取值范围为1~65535。
global-port:外网端口号,缺省值以及取值范围的要求和local-port的规定一致。
local-address:服务器的内网IP地址。
vpn-instance global-name:对外公布的外网地址所属的VPN。global-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示对外公布的外网地址不属于任何一个VPN。
vpn-instance local-name:内部服务器所属的VPN。local-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示内部服务器不属于任何一个VPN。
server-group group-number:服务器在内网所属的服务器组。若指定了该参数,则表示要配置一个负载分担内部服务器。group-number表示内部服务器组编号,取值范围为0~65535。
acl acl-number:指定ACL编号,取值范围为2000~3999。若指定了该参数,则表示与指定的ACL permit规则匹配的报文才可以使用内部服务器的映射表进行地址转换。
通过该配置可以利用NAT设备将一些内部网络的服务器提供给外部网络使用,例如内部的Web服务器、FTP服务器、Telnet服务器、POP3服务器、DNS服务器等。这些内部服务器可以位于普通的内网内,也可以位于MPLS VPN实例内。
NAT内部服务器通常配置在NAT设备的外网侧接口上。外网用户可以通过global-address定义的外网地址和global-port定义的外网端口来访问内网地址和内网端口分别为local-addresslocal-port的内部服务器。NAT内部服务器支持以下几种内网和外网的地址、端口映射关系。
表1-16 NAT内部服务器的地址与端口映射关系
外网
内网
一个外网地址
一个内网地址
一个外网地址、一个端口号
一个内网地址、一个内网端口号
一个外网地址,N个连续的外网端口号
一个内网地址,一个内网端口
N个连续的内网地址,一个内网端口号
一个内网地址,N个连续的内网端口号
N个连续的外网地址
一个内网地址
N个连续的内网地址
N个连续的外网地址连续,一个外网端口号
一个内网地址,一个内网端口号
N个连续的内网地址,一个内网端口号
一个内网地址,N个连续的内网端口号
一个外网地址,一个外网端口号
一个内部服务器组
一个外网地址,N个连续的外网端口号
N个连续的外网地址,一个外网端口号
·              一个接口下允许配置的nat server命令个数与设备的型号有关。每个nat server命令下可以配置的NAT内部服务器数目为global-port2global-port1的差值,即配置多少个外网端口就对应多少个NAT内部服务器。
·              设备支持引用接口地址作为NAT内部服务器的外网地址(Easy IP方式)。如果配置关键字current-interface,表示外网地址使用的是当前接口的当前主地址;如果指定具体的接口,则只能指定Loopback接口,外网地址使用的是配置的Loopback接口的当前主地址。
·              由于Easy IP方式的NAT内部服务器使用了当前接口或其它接口的IP地址作为它的外网地址,因此强烈建议在配置了Easy IP方式的NAT内部服务器之后,其它NAT内部服务器不要再配置该接口的IP地址作为它的外网地址,反之亦然。
·              pro-type不是TCP(协议号为6)或UDP(协议号为17)时,用户只能设置内部IP地址与外部IP地址的一一对应的关系,无法设置端口号之间的映射。
·              对于同一个接口下配置的NAT服务器,其协议类型、外网地址和外网端口号的组合必须是唯一的,否则认为是配置冲突。本规则同样适用于Easy IP方式的NAT服务器,其外网地址为指定接口的IP地址。
·              对于同一个接口下配置的Easy IP方式的NAT服务器,其协议类型、接口名和外网端口的组合必须是唯一的,否则认为是配置冲突。
·              对于Easy IP方式的NAT服务器,如果其引用的接口的IP地址发生改变,导致跟现有的其它非Easy IP方式的NAT服务器冲突,则Easy IP方式的NAT服务器配置失效;如果接口地址又修改为不冲突的IP,或者之前与之冲突的NAT服务器被删除,则Easy IP方式的NAT配置重新生效。
# 在接口GigabitEthernet1/0/1上配置NAT内部服务器,指定局域网内部的Web服务器的IP地址是10.110.10.10,希望外部通过http://202.110.10.10:8080可以访问Web服务器。
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
# 在接口GigabitEthernet1/0/1上配置NAT内部服务器,指定一个内部的主机10.110.10.12,希望外部网络的主机可以利用ping 202.110.10.11命令ping通它。
[Sysname-GigabitEthernet1/0/1] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12
# 在接口GigabitEthernet1/0/1上配置NAT内部服务器,指定一个外部地址202.110.10.10,从端口1001~1100分别映射主机10.110.10.1~10.110.10.100的telnet服务。202.110.10.10:1001访问10.110.10.1,202.110.10:1002访问10.110.10.2,依此类推。
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet
·              display nat all
·              display nat server
·              nat server-group
1.1.33  nat server-group
nat server-group命令用来配置一个内部服务器组。
undo nat server-group命令用来删除指定的内部服务器组。
nat server-group group-number
undo nat server-group group-number
不存在内部服务器组。
group-number服务器组编号,取值范围为0~65535
一个内部服务器组中可以包括多个内部服务器组成员(通过inside ip命令配置)。
# 配置一个内部服务器组,编号为1。
·              display nat all
·              display nat server-group
·              inside ip
·              nat server
1.1.34  nat service
nat service命令用来指定提供NAT处理的业务板。
undo nat service命令用来恢复缺省情况。
undo nat service slot
未指定提供NAT处理的业务板。
slot slot-number:指定单板所在的槽位号。slot-number表示单板所在的槽位号。
对于支持本命令的设备,必须在配置了NAT业务的接口上指定提供NAT处理的业务板。只有为接口指定了业务板,接口的NAT功能才能生效。
·              一个接口上的NAT业务只能由一块业务板处理,该业务板可以是设备上的任意可提供NAT处理的业务板。通常,如果接口所在的板具有NAT处理能力,那么建议将接口所在板指定为NAT业务板。
l   如果要修改接口下指定的业务板,需要先恢复缺省情况再重新指定。
l   多个接口引用了同一个地址组或外网地址时,这些接口必须指定同一块业务板进行NAT处理。否则,可能会出现配置成功但实际不生效的情况,并且在配置恢复(由设备重启、软件升级等原因导致)时可能会造成配置丢失。
# 指定5号单板作为提供NAT处理的业务板。
[Sysname-GigabitEthernet1/0/1] nat service slot 5
1.1.35  nat static enable
nat static enable命令用来开启接口上的NAT静态地址转换功能。
undo nat static enable命令用来关闭接口上的NAT静态地址转换功能。
nat static enable
NAT静态地址转换功能处于关闭状态。
接口下开启NAT静态地址转换功能后,所有已配置的静态地址转换映射都会在该接口上生效。
# 配置内网IP地址192.168.1.1到外网IP地址2.2.2.2的出方向一对一静态地址转换,并且在接口GigabitEthernet1/0/1上开启静态地址转换功能。
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-GigabitEthernet1/0/1] nat static enable
·              display nat all
·              display nat static
·              nat static
1.1.36  nat static inbound
nat static inbound命令用来配置入方向一对一静态地址转换映射。
undo nat static inbound命令用来删除指定的入方向一对一静态地址转换映射。
nat static inbound global-ip [ vpn-instance global-name ] local-ip [ vpn-instance local-name ] [ acl acl-number [ reversible ] ]
undo nat static inbound global-ip [ vpn-instance global-name ]
不存在任何地址转换映射。
global-ip:外网IP地址。
vpn-instance global-name:外网IP地址所属的VPN。global-name表示MPLS L3VPNVPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示外网IP地址不属于任何一个VPN。
local-ip:内网IP地址。
vpn-instance local-name:内网IP地址所属的VPN。local-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示内网IP地址不属于任何一个VPN。
acl acl-number:ACL编号,取值范围为3000~3999。本参数用于控制指定源地址的内网主机可以访问外网。
reversible:表示从内网主动访问外网的报文必须通过ACL反向匹配,才能使用该配置进行目的地址转换。
对于从外网到内网的报文,将其源地址global-ip转换为local-ip;对于从内网到外网的报文,将其目的地址local-ip转换为global-ip
·              如果没有指定ACL,则所有从外网到内网的报文都可以使用该配置进行源地址转换;所有从内网到外网的报文都可以使用该配置进行目的地址转换。
·              如果仅指定了ACL,没有指定ACL反向匹配(即没有配置reversible),对于从外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网主动访问外网的报文,不能使用该配置进行目的地址转换。
·              如果既指定了ACL,又指定了ACL反向匹配(即配置了reversible),对于外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网主动访问外网的报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并根据配置转换目的地址,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能使用该配置进行转换,否则不予转换。
·              如果接口下既配置了NAT动态地址转换,又使能了NAT静态地址转换,则优先使用静态地址转换。
·              设备可支持配置多条入方向静态地址转换映射(包括nat static inboundnat static inbound net-to-net)。
# 配置外网IP地址2.2.2.2到内网IP地址192.168.1.1的入方向静态地址转换。
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
·              display nat all
·              nat static enable
1.1.37  nat static inbound net-to-net
nat static inbound net-to-net命令用来配置入方向网段到网段的静态地址转换映射。
undo nat static inbound net-to-net命令用来删除指定的入方向网段到网段的静态地址转换映射。
nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global -name ] local local-network { mask-length | mask } [ vpn-instance local-name ] [ acl acl-number [ reversible ] ]
undo nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global -name ]
不存在任何地址转换映射。
global-start-address global-end-address:外网地址范围,所包含的地址数目不能超过256global-start-address表示起始地址,global-end-address表示结束地址。global-end-address必须大于或等于global-start-address,如果二者相同,则表示只有一个地址。
local-network:内网网段地址。
mask-length:内网网络地址的掩码长度,取值范围为8~31。
mask:内网网络地址掩码。
外网网段通过起始地址和结束地址来指定,内网网段通过内网地址和掩码来指定。
对于从外网到内网的报文,使用其源地址匹配外网地址,将源地址转换为内网地址;对于从内网到外网的报文,使用其目的地址匹配内网地址,将目的地址转换为外网地址。
·              外网结束地址不能大于外网起始地址和内网掩码所决定的网段中的最大IP地址。比如:内网地址配置为2.2.2.0,掩码为255.255.255.0,外网起始地址为1.1.1.100,则外网结束地址不应该大于1.1.1.0/24网段中可用的最大IP地址,即1.1.1.255。
·              如果仅指定了ACL,没有指定ACL反向匹配(即没有配置reversible),对于从外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网到外网的报文,不能使用该配置进行目的地址转换。
·              如果既指定了ACL,又指定了ACL反向匹配(即配置了reversible),对于外网到内网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从内网到外网的报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并根据配置转换目的地址,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能使用该配置进行转换,否则不予转换。
·              设备支持配置多条入方向静态地址转换映射(包括nat static inboundnat static inbound net-to-net)。
# 配置外网网段202.100.1.0/24到内网网段192.168.1.0/24的入方向静态地址转换。
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
·              display nat all
·              nat static enable
1.1.38  nat static outbound
nat static outbound命令用来配置出方向一对一静态地址转换映射。
undo nat static outbound命令用来删除出方向一对一静态地址转换映射。
nat static outbound local-ip [ vpn-instance local-name ] global-ip [ vpn-instance global-name ] [ acl acl-number [ reversible ] ]
undo nat static outbound local-ip [ vpn-instance local-name ]
不存在任何地址转换映射。
local-ip:内网IP地址。
global-ip:外网IP地址。
acl acl-number:ACL编号,取值范围为3000~3999。本参数用于控制内网主机可以访问的目的地址。
reversible:表示从外网主动访问内网的报文必须通过ACL反向匹配,才能使用该配置进行目的地址转换。
对于从内网到外网的报文,将其源地址local-ip转换为global-ip;对于从外网到内网的报文,将其目的地址global-ip转换为local-ip
·              如果没有指定ACL,则所有从内网到外网的报文都可以使用该配置进行源地址转换;所有从外网到内网的报文都可以使用该配置进行目的地址转换。
·              如果仅指定了ACL,没有指定ACL反向匹配(即没有配置reversible),对于从内网到外网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从外网主动访问内网的报文,不能使用该配置进行目的地址转换。
·              如果既指定了ACL,又指定了ACL反向匹配(即配置了reversible),对于从内网到外网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从外网主动访问内网的报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并根据配置转换目的地址,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能使用该配置进行转换,否则不予转换。
·              设备可支持配置多条出方向静态地址转换映射(包括nat static outboundnat static outbound net-to-net)。
# 配置内网IP地址192.168.1.1到外网IP地址2.2.2.2的出方向静态地址转换映射。
# 配置出方向静态地址转换映射,允许内网用户192.168.1.1访问外网网段3.3.3.0/24时,使用外网IP地址2.2.2.2。
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
·              display nat all
·              nat static enable
1.1.39  nat static outbound net-to-net
nat static outbound net-to-net命令用来配置出方向网段到网段的静态地址转换映射。
undo nat static outbound net-to-net命令用来删除出方向网段到网段的静态地址转换映射。
nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-name ] global global-network { mask-length | mask } [ vpn-instance global-name ] [ acl acl-number [ reversible ] ]
undo nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-name ]
不存在任何地址转换映射。
local-start-address local-end-address:内网地址范围,所包含的地址数目不能超过255local-start-address 表示起始地址,local-end-address表示结束地址。local-end-address必须大于或等于local-start-address,如果二者相同,则表示只有一个地址。
global-network:外网网段地址。
mask-length:外网网络地址的掩码长度,取值范围为8~31。
mask:外网网络地址掩码。
内网网段通过起始地址和结束地址来指定,外网网段通过外网地址和掩码来指定。
对于从内网到外网的报文,使用其源地址匹配内网地址,将源地址转换为外网地址;对于从外网到内网的报文,使用其目的地址匹配外网地址,将目的地址转换为内网地址。
·              内网结束地址不能大于内网起始地址和外网掩码所决定的网段中的最大IP地址。比如:外网地址配置为2.2.2.0,掩码为255.255.255.0,内网起始地址为1.1.1.100,则内网结束地址不应该大于1.1.1.0/24网段中可用的最大IP地址,即1.1.1.255。
# 配置内网网段192.168.1.0/24到外网网段2.2.2.0/24的出方向静态地址转换映射。
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# 配置出方向网段到网段的静态地址转换映射,允许内网192.168.1.0/24网段的用户访问外网网段3.3.3.0/24时,使用外网网段2.2.2.0/24中的地址。
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
·              display nat all
·              nat static enable
1.1.40  port-block
port-block命令用来配置NAT地址组的端口块参数。
undo port-block命令用来删除NAT地址组的端口块参数。
port-block block-size block-size [ extended-block-number extended-block-number ]
undo port-block
NAT地址组未配置端口块参数。
NAT地址组视图
block-size block-size:端口块大小,即一个端口块中所包含的端口数,取值范围为1~65535。同一NAT地址组内,该参数的值不能超过port-range参数的值。
extended-block-number extended-block-number:增量端口块数,取值范围为1~5。当分配端口块中的端口资源耗尽(所有端口都被使用)时,如果对应的私网IP地址向公网发起新的连接,则无法从分配端口块中获取端口。此时,如果分配端口块的公网IP地址所属的NAT地址组中配置了增量端口块数,则可以为对应的私网IP地址进行增量端口块分配。一个私网IP地址最多可同时占有1+extended-block-number个端口块。
端口块动态映射方式下,配置出方向地址转换所引用的NAT地址组中必须配置端口块参数。当某私网IP地址首次向公网发起连接时,从所匹配的NAT地址组中获取一个公网IP地址,从获取的公网IP地址中分配一个动态端口块并创建动态端口块表项(该私网IP地址后续向公网发起连接时,通过私网IP地址查找动态端口块表项),使用公网IP地址进行IP地址转换,并从端口块中动态分配一个端口进行TCP/UDP端口转换。
# 配置NAT地址组2的端口块参数,端口块大小为256,增量端口块数为1。
[Sysname-nat-address-group-2] port-block block-size 256 extended-block-number 1
·              nat address-group
1.1.41  port-range
port-range命令用来配置公网IP地址的端口范围。
undo port-range命令用来恢复缺省情况。
port-range start-port-number end-port-number
undo port-range
公网IP地址的端口范围为1~65535。
NAT地址组视图/NAT端口块组视图
start-port-number end-port-number:公网IP地址端口的起始端口号和结束端口号。end-port-number必须大于或等于start-port-number
在NAT地址组(或NAT端口块组)视图下配置端口范围后,该NAT地址组(或NAT端口块组)内的所有公网IP地址可用于地址转换的端口都必须位于所指定的端口范围之内。
在NAT端口块组内配置端口范围时,端口范围不能小于端口块大小。在NAT地址组内配置端口范围时,如果地址组配置了端口块参数,则端口范围也不能小于端口块大小。
# 配置NAT地址组1的公网IP地址端口范围为1024~65535。
[Sysname-nat-address-group-1] port-range 1024 65535
# 配置NAT端口块组1的公网IP地址端口范围为30001~65535。
[Sysname] nat port-block-group 1
[Sysname-nat-port-block-group-1] port-range 30001 65535
·              nat address-group
1.1.42  reset nat service statistics slot
reset nat service statistics slot 命令用来删除指定单板上NAT地址转换的统计信息。
reset nat service statistics slot slot-number
# 删除2号单板的NAT地址转换的统计信息。
<Sysname> reset nat service statistics slot 2
·              display nat service slot
1.1.43  reset nat session
reset nat session命令用来删除NAT会话。
reset nat session [ slot slot-number ]
slot slot-number:删除指定单板上的NAT会话,slot-number表示单板所在的槽位号。如果不指定该参数,则表示删除所有单板上的NAT会话。
NAT会话被删除之后,与其相关的NAT EIM表和NO-PAT表也会同时删除。
# 删除2号单板的NAT会话。
<Sysname> reset nat session slot 2
·              display nat session
