08-IP组播命令参考
13-MLD命令
本章节下载 13-MLD命令  (443.87 KB)
13-MLD命令
  录
1 MLD
1.1 MLD配置命令
1.1.1 display mld attack-suppression per-interface configuration
1.1.2 display mld attack-suppression per-interface entry
1.1.3 display mld attack-suppression source-mac configuration
1.1.4 display mld attack-suppression source-mac entry
1.1.5 display mld group
1.1.6 display mld interface
1.1.7 display mld proxy group
1.1.8 display mld proxy routing-table
1.1.9 display mld ssm-mapping
1.1.10 display mld user-authorization
1.1.11 last-listener-query-count (MLD view)
1.1.12 last-listener-query-interval (MLD view)
1.1.13 max-response-time (MLD view)
1.1.14 mld
1.1.15 mld access-policy
1.1.16 mld attack-suppression per-interface aging-time
1.1.17 mld attack-suppression per-interface check-interval
1.1.18 mld attack-suppression per-interface enable
1.1.19 mld attack-suppression per-interface threshold
1.1.20 mld attack-suppression source-mac aging-time
1.1.21 mld attack-suppression source-mac check-interval
1.1.22 mld attack-suppression source-mac enable
1.1.23 mld attack-suppression source-mac threshold
1.1.24 mld authorization-enable
1.1.25 mld enable
1.1.26 mld fast-leave
1.1.27 mld group-policy
1.1.28 mld join-by-session
1.1.29 mld last-listener-query-count
1.1.30 mld last-listener-query-interval
1.1.31 mld max-response-time
1.1.32 mld non-stop-routing
1.1.33 mld other-querier-present-timeout
1.1.34 mld proxy enable
1.1.35 mld proxy forwarding
1.1.36 mld query-interval
1.1.37 mld robust-count
1.1.38 mld startup-query-count
1.1.39 mld startup-query-interval
1.1.40 mld static-group
1.1.41 mld user-vlan-aggregation dot1q
1.1.42 mld version
1.1.43 other-querier-present-timeout (MLD view)
1.1.44 proxy multipath (MLD view)
1.1.45 query-interval (MLD view)
1.1.46 reset mld attack-suppression per-interface entry
1.1.47 reset mld attack-suppression per-interface statistics
1.1.48 reset mld attack-suppression source-mac entry
1.1.49 reset mld attack-suppression source-mac statistics
1.1.50 reset mld group
1.1.51 robust-count (MLD view)
1.1.52 ssm-mapping (MLD view)
1.1.53 startup-query-count (MLD view)
1.1.54 startup-query-interval (MLD view)
1 MLD
1.1  MLD配置命令
display mld attack-suppression per-interface configuration命令用来显示基于接口的MLD攻击检测相关配置信息。
# 显示基于接口的MLD攻击检测相关配置信息。
<Sysname> display mld attack-suppression per-interface configuration
MLD attack-suppression per-interface is enabled.
Check interval: 5s
Threshold: 20
Aging time: 300s
表1-1 display mld attack-suppression per-interface configuration命令显示信息描述表
Check interval
MLD基于接口的MLD攻击检测周期
Threshold
MLD基于接口的MLD攻击抑制阈值
Aging time
MLD基于接口的攻击检测表项老化时间
·     mld attack-suppression per-interface aging-time
·     mld attack-suppression per-interface check-interval
·     mld attack-suppression per-interface enable
·     mld attack-suppression per-interface threshold
display mld attack-suppression per-interface entry命令用来显示基于接口的MLD攻击检测表项。
(独立运行模式)
display mld attack-suppression per-interface entry slot slot-number [ interface interface-type interface-number ] [ attack ] [ verbose ]
display mld attack-suppression per-interface entry chassis chassis-number slot slot-number [ interface interface-type interface-number ] [ attack ] [ verbose ]
interface interface-type interface-number:显示指定接口上的MLD攻击检测表项,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,则显示所有接口下的MLD攻击检测表项。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
attack:显示基于接口的MLD攻击报文的攻击检测表项。如果未指定本参数,则显示所有已创建的MLD攻击检测表项。
verbose:显示基于接口的MLD攻击检测表项的详细信息。如果未指定本参数,则显示简要信息。
# 显示基于接口的MLD攻击报文的攻击检测表项。(独立运行模式)
<Sysname> display mld attack-suppression per-interface entry slot 1 attack
Total entries: 1
Interface            Attack start time      Expires
GE1/0/4              2018/09/10 15:53:34    00:01:15
# 显示基于接口的MLD攻击检测表项的详细信息。(独立运行模式)
<Sysname> display mld attack-suppression per-interface entry slot 1 verbose
Total entries: 2
Interface: GE1/0/1
Drv status: N/A
Attack start time: N/A
Expires: Off
CPU receive: 10
CPU drop: 0
Drv drop: 0
Interface: GE1/0/2
Drv status: Succeeded
Attack start time: 2018/09/10 15:53:34
Expires: 00:01:15
CPU receive: 123456789
CPU drop: 123456
Drv drop: 18446744073709551615
表1-2 display mld attack-suppression per-interface 命令显示信息描述表
Total entries
MLD攻击检测表项总数
接口名称
Drv status
驱动状态:
·     Succeeded:下驱动成功,产品通过硬件限速
·     Failed:下驱动失败,可能设备故障或硬件攻击表项资源已被占满。此时通过软件进行限速
·     N/A:当前表项对应的报文为非攻击报文,尚未下驱动
Attack start time
检测到攻击开始的时间,N/A表示还未检测到攻击
Expires
MLD攻击检测表项的超时时间,Off表示该定时器关闭
CPU receive
CPU收到报文数
CPU drop
CPU丢弃的报文数
Drv drop
驱动丢弃的报文数
·     reset mld attack-suppression per-interface entry
display mld attack-suppression source-mac configuration命令用来显示基于源MAC地址的MLD攻击检测相关配置信息。
# 显示基于源MAC地址的MLD攻击检测相关配置信息。
<Sysname> display mld attack-suppression source-mac configuration
MLD attack-suppression source-mac is enabled.
Check interval: 5s
Threshold: 20
Aging time: 300s
表1-3 display mld attack-suppression source-mac configuration命令显示信息描述表
Check interval
MLD基于源MAC地址的MLD攻击检测周期
Threshold
MLD基于源MAC地址的MLD攻击抑制阈值
Aging time
MLD基于源MAC地址的攻击检测表项老化时间
·     mld attack-suppression source-mac aging-time
·     mld attack-suppression source-mac check-interval
·     mld attack-suppression source-mac enable
·     mld attack-suppression source-mac threshold
display mld attack-suppression source-mac entry命令用来显示基于源MAC地址的MLD攻击检测表项。
(独立运行模式)
display mld attack-suppression source-mac entry slot slot-number [ interface interface-type interface-number | mac-address address ]* [ attack ] [ verbose ]
display mld attack-suppression source-mac entry chassis chassis-number slot slot-number [ interface interface-type interface-number | mac-address address ]* [ attack ] [ verbose ]
interface interface-type interface-number:显示指定接口上基于源MAC地址的MLD攻击检测表项,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,则显示所有接口上的MLD攻击检测表项。
mac-address address:显示指定源MAC地址对应的MLD攻击检测表项。如果未指定本参数,则显示所有MAC地址对应的MLD攻击检测表项。
attack:显示基于源MAC地址的MLD攻击报文的攻击检测表项。如果未指定本参数,则显示所有已创建的MLD攻击检测表项。
verbose:显示基于源MAC地址的MLD攻击检测表项的详细信息。如果未指定本参数,则显示简要信息。
# 显示基于源MAC地址的MLD攻击报文的攻击检测表项。(独立运行模式)
<Sysname> display mld attack-suppression source-mac entry slot 1 attack
Total entries: 1
Interface            MAC address       Attack start time      Expires
GE1/0/4              0001-0001-0004    2018/09/10 15:53:34    00:01:15
# 显示基于源MAC地址的MLD攻击检测表项的详细信息。(独立运行模式)
<Sysname> display mld attack-suppression source-mac entry slot 1 verbose
Total entries: 2
Interface: GE1/0/1
MAC address: 0001-0001-0001
Drv status: N/A
Expires: Off
CPU receive: 10
CPU drop: 0
Drv drop: 0
Interface: GE1/0/2
MAC address: 0001-0001-0002
Expires: 00:01:15
CPU drop : 123456
Drv drop : 18446744073709551615
表1-4 display mld attack-suppression source-mac命令显示信息描述表
Total entries
MLD攻击检测表项总数
接口名称
MAC address
攻击者的MAC地址
Drv status
驱动状态:
Attack start time
Expires
CPU receive
CPU收到报文数
CPU drop
CPU丢弃的报文数
Drv drop
驱动丢弃的报文数
·     reset mld attack-suppression source-mac entry
display mld group命令用来显示MLD组播组(即通过MLD加入的IPv6组播组)的信息。
display mld group [ ipv6-group-address | interface interface-type interface-number ] [ static | verbose ]
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息。
interface interface-type interface-number:显示指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的信息。
static:显示静态加入的IPv6组播组信息。如果未指定本参数,将只显示动态加入的IPv6组播组信息。
verbose:显示详细信息。
# 显示公网实例中动态加入的所有MLD组播组信息。
<Sysname> display mld group
MLD groups in total: 1
 GigabitEthernet3/1/1(FE80::101):
  MLD groups reported in total: 1
   Group address: FF03::101
    Last reporter: FE80::10
    Uptime: 00:02:04
    Expires: 00:01:15
表1-5 display mld group命令显示信息描述表
MLD groups in total
MLD组播组的总数
当前接口上动态加入的MLD组播组总数
Group address
IPv6组播组地址
Last reporter
最后发送报告报文的主机地址
Uptime
IPv6组播组的运行时间
Expires
IPv6组播组的超时时间,Off表示该定时器关闭
# 显示公网实例中动态加入的MLD组播组FF3E::101的详细信息(假设当前运行MLDv2)。
<Sysname> display mld group ff3e::101 verbose
   Group: FF3E::101
     Uptime: 00:01:46
     Exclude expires: 00:04:16
     Mapping expires: 00:02:16
     Last-listener-query-counter: 0
     Last-listener-query-timer-expiry: Off
     Mapping last-listener-query-counter: 0
     Mapping last-listener-query-timer-expiry: Off
     Group mode: Exclude
     Version1-host-present-timer-expiry: Off
     Source list (sources in total: 1):
       Source: 10::10
          Uptime: 00:00:09
          V2 expires: 00:04:11
表1-6 display mld group verbose命令显示信息描述表
当前接口上动态加入的MLD组播组总数
Group
IPv6组播组地址
Uptime
IPv6组播组的运行时间
Exclude expires
EXCLUDE模式下IPv6组播组的超时时间,Off表示该定时器关闭
Mapping expires
MLD SSM Mapping规则所生成IPv6组播组的超时时间。只有运行MLD SSM Mapping时才会显示本字段
Last reporter
最后发送报告报文的主机地址
最后组成员查询次数
最后组成员查询定时器的超时时间,Off表示该定时器关闭
MLD SSM Mapping规则所生成IPv6组播组的最后组成员查询次数。只有运行MLD SSM Mapping时才会显示本字段
MLD SSM Mapping规则所生成IPv6组播组的最后组成员查询定时器的超时时间,Off表示该定时器关闭。只有运行MLD SSM Mapping时才会显示本字段
Group mode
对IPv6组播源的过滤模式:
·     Include:表示INCLUDE模式
·     Exclude:表示EXCLUDE模式,对于未运行MLD SSM Mapping的MLDv1,也显示为本模式
MLDv1本身并不区分过滤模式,但当运行MLD SSM Mapping时,会根据具体配置以及加入的IPv6组播组来显示相应的模式;而当未运行MLD SSM Mapping时,则固定显示为Exclude
MLDv1主机超时时间,Off表示该定时器关闭。只有运行MLDv2时才会显示本字段
IPv6组播源列表及总数。只有运行MLDv2或MLD SSM Mapping时才会显示本字段
Source
IPv6组播源地址。只有运行MLDv2或MLD SSM Mapping时才会显示本字段
Uptime
IPv6组播源的运行时间。只有运行MLDv2或MLD SSM Mapping时才会显示本字段
V2 expires
MLDv2组播源的超时时间,Off表示该定时器关闭,“---”表示该组播源由MLD SSM Mapping规则生成。只有运行MLDv2或MLD SSM Mapping时才会显示本字段
Mapping expires
MLD SSM Mapping规则所生成IPv6组播源的超时时间。只有运行MLD SSM Mapping时才会显示本字段
最后源组成员查询次数。只有运行MLDv2或MLD SSM Mapping时才会显示本字段
最后源组成员查询定时器的超时时间,Off表示该定时器关闭。只有运行MLDv2或MLD SSM Mapping时才会显示本字段
# 显示公网实例中静态加入的MLD组播组信息。
<Sysname> display mld group static
 Entries in total: 2
  (*, FF03::101)
   Interface: GE3/1/1
   Expires: Never
  (2001::101, FF3E::202)
   Interface: GE3/1/1
   Expires: Never
表1-7 display mld group static命令显示信息描述表
Entries in total
MLD组播组的总数
(*, FF03::101)
*,G)表项
(S,G)表项
接口名称
Expires
IPv6组播组的超时时间,固定显示为Never,表示永不超时
·     reset mld group
display mld interface命令用来显示接口上MLD配置和运行的信息。
display mld interface [ interface-type interface-number ] [ proxy ] [ verbose ]
display mld interface [ access-interface interface-type interface-number ] [ verbose ]
access-interface interface-type interface-number:显示从指定接口接入的IPv6组播用户的MLD配置和运行信息。
interface-type interface-number:显示指定接口上MLD配置和运行信息。
proxy:显示代理接口的信息。
verbose:显示详细信息。
如果在ISP域配置了service-type stb,且用户成功登录,IPoE、PPPoE和Portal等接入模块会向MLD通知上线IPv6组播用户。配置按会话记录用户加入的IPv6组播组之后,MLD根据该用户信息创建对应的Multicast-UA接口,并将MLD配置和运行信息维护在Multicast-UA接口。每个IPv6组播用户与Multicast-UA接口一一对应,通过Multicast-UA接口来区分IPv6组播用户。此时用户端的MLD配置和运行信息维护在其对应的Multicast-UA接口上。接入IPv6组播用户的实际接口,称为该Multicast-UA接口的Access-Interface。有关service-type stb的详细介绍,请参见“BRAS业务配置指导”中的“AAA”。
如果IPv6组播用户通过QinQ方式接入,MLD通过MLD Report报文内容为IPv6组播用户创建Multicast-UA接口,当Multicast-UA接口下不存在MLD组且一段时间没有收到MLD Report报文后,Multicast-UA接口将会老化并删除。有关QinQ的详细介绍,请参见“二层技术-以太网交换”中的“QinQ”。
通过display mld interface access-interface interface-type interface-number命令可以显示所有Access-Interface相同的Multicast-UA接口的MLD配置和运行信息。
执行本命令时,如果未指定任何参数,将显示所有接口上MLD配置和运行的信息。
# 显示公网实例接口GigabitEthernet3/1/1(非代理接口)上MLD配置和运行的详细信息。
<Sysname> display mld interface gigabitethernet 3/1/1 verbose
 GigabitEthernet3/1/1(FE80::200:AFF:FE01:101):
   MLD is enabled.
   MLD version: 1
   Query interval for MLD: 125s
   Other querier present time for MLD: 255s
   Maximum query response time for MLD: 10s
   Last listener query interval: 1s
   Last listener query count: 2
   Startup query interval: 31s
   Startup query count: 2
   General query timer expiry (hh:mm:ss): 00:00:23
   Querier for MLD: FE80::200:AFF:FE01:101 (This router)
   MLD activity: 1 join(s), 0 done(s)
   IPv6 multicast routing on this interface: Enabled
   Robustness: 2
   Require-router-alert: Disabled
   Fast-leave: Disabled
   Startup-query: Off
   Other-querier-present-timer-expiry (hh:mm:ss): Off
   Authorization: Disabled
   Join-by-session: Disabled
   User-VLAN-aggregation: Disabled
   Access interface: GigabitEthernet3/1/1
# 显示公网实例所有代理接口上MLD配置和运行的详细信息。
<Sysname> display mld interface proxy verbose
 GigabitEthernet3/1/2(FE80::100:CEF:FE01:101):
   MLD proxy is enabled.
   MLD version: 1
   Version1-querier-present-timer-expiry: Off
# 显示公网实例内指定接口上接入的所有IPv6组播用户接口详细信息。
<Sysname> display mld interface access-interface gigabitethernet 3/1/2 verbose
 Multicast-UA0(FE80::102:2):
   MLD is enabled.
   MLD version: 1
   General query timer expiry (hh:mm:ss): 00:01:14
   Querier for MLD: FE80::102:2 (This router)
   MLD activity: 0 join(s), 0 done(s)
   Robustness: 2
   Startup-query: Off
   Join-by-session: Enabled
   Access interface: GigabitEthernet3/1/2
表1-8 display mld interface命令显示信息描述表
接口的名称和IPv6链路本地地址
MLD is enabled
接口已使能MLD
MLD version
此接口运行的MLD版本
MLD普遍组查询报文的发送间隔(秒)
MLD其它查询器的存在时间(秒)
MLD普遍组查询报文的最大响应时间(秒)
最后组成员查询间隔(秒)
最后组成员查询次数
MLD查询器启动查询间隔(秒)
Startup query count
MLD查询器启动查询次数
MLD普遍组查询的超时时间,off表示该定时器关闭
Querier for MLD
MLD查询器的IPv6链路本地地址
MLD的活动统计:
·     join(s):表示加入过的IPv6组播组总数
·     done(s):表示离开过的IPv6组播组总数
是否使能IPv6组播路由:
·     Enabled:表示已使能
·     Disabled:表示未使能
Robustness
MLD查询器的健壮系数
是否开启丢弃未携带Router-Alert选项的MLD报文功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
Fast-leave
是否开启快速离开功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
Startup-query
是否处于启动查询状态:
·     On:表示处于启动查询状态
·     Off:表示未处于启动查询状态
MLD其它查询器的存在超时时间,Off表示该定时器关闭
Authorization
是否开启IPv6可控组播功能:
·     Enabled:表示已开启
·     Disabled:表示未开启
Join-by-session
是否开启按会话记录用户加入的IPv6组播组:
·     Enabled:表示已开启
·     Disabled:表示未开启
是否开启为IPv6组播报文封装VLAN Tag:
·     Enabled:表示已开启
·     Disabled:表示未开启
Access interface
用户的实际接入接口。如果MLD信息不是维护在Multicast-UA接口,则不显示本字段
此接口上动态加入的IPv6组播组数量。没有加入组时不显示本字段
MLD代理功能已开启
MLDv1查询器的存在超时时间,如果查询器不存在,则显示为Off
display mld proxy group命令用来显示MLD代理记录的IPv6组播组信息。
display mld proxy group [ ipv6-group-address | interface interface-type interface-number ] [ verbose ]
interface interface-type interface-number:显示指定接口上的信息。如果未指定本参数,将显示所有接口上的信息。
verbose:显示详细信息。
# 显示公网实例中MLD代理记录的所有IPv6组播组信息。
<Sysname> display mld proxy group
MLD proxy group records in total: 2
 GigabitEthernet3/1/1(FE80::16:1):
   Group address: FF1E::1
    Member state: Idle
    Expires: Off
   Group address: FF1E::2
    Member state: Idle
    Expires: Off
# 显示公网实例中MLD代理记录的IPv6组播组FF1E::1的详细信息。
<Sysname> display mld proxy group ff1e::1 verbose
   Group: FF1E::1
     Group mode: Include
     Member state: Idle
     Expires: Off
       100::1
表1-9 display mld proxy group命令显示信息描述表
MLD代理记录的IPv6组播组总数
MLD代理接口的名称和IPv6地址
Pending proxy group
等待生效的代理组
Group address/Group
IPv6组播组地址
Member state
IPv6组播组成员的状态,其中:
·     Delay:表示加入了一个组,并对该组启动了延迟发送报告报文的定时器
·     Idle:表示加入了一个组,但对该组尚未启动延迟发送报告报文的定时器
Expires
IPv6组播组延迟发送报告报文的时间,Off表示该定时器关闭
Group mode
对IPv6组播源的过滤模式,其中:
MLD代理的IPv6组播组所包含的IPv6组播源列表和IPv6组播源的总数
display mld proxy routing-table命令用来显示MLD代理路由表的信息。
display mld proxy routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] ] * [ verbose ]
ipv6-source-address:显示指定IPv6组播源的信息。如果未指定本参数,将显示所有IPv6组播源的信息。
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播源地址,其取值范围为0~128,缺省值为128;对于IPv6组播组地址,其取值范围为8~128,缺省值为128。
verbose:显示详细信息。
# 显示公网实例MLD代理路由表的信息。
<Sysname> display mld proxy routing-table
 Total 1 (*, G) entries, 2 (S, G) entries.
 (100::1, FF1E::1)
     Upstream interface: GigabitEthernet3/1/1
     Downstream interfaces (1 in total):
         1: GigabitEthernet3/1/2
             Protocol: MLD
 (*, FF1E::2)
             Protocol: STATIC
 (2::2, FF1E::2)
     Downstream interfaces (2 in total):
         1: LoopBack1
             Protocol: STATIC
         2: GigabitEthernet3/1/2
             Protocol: PROXY
# 显示公网实例MLD代理路由表的详细信息。
<Sysname> display mld proxy routing-table verbose
 (100::1, FF1E::1)
             Protocol: MLD
             Querier state: Querier
             Join/Prune state:Join
     Non-downstream interfaces: None
 (*, FF1E::2)
             Protocol: STATIC
     Non-downstream interfaces (1 in total):
         1: GigabitEthernet3/1/3
             Protocol: MLD
             Querier state: Non-querier
 (2::2, FF1E::2)
         1: LoopBack1
             Protocol: STATIC
             Join/Prune state: Join
             Protocol: PROXY
表1-10 display mld proxy routing-table命令显示信息描述表
(S,G)表项和(*,G)表项的总数
(100::1, FF1E::1)
(S,G)表项
Upstream interface
表项的入接口
下游的出接口信息及总数
下游的非出接口信息及总数
接口的索引号及接口名称
Protocol
接口使用的协议类型:
·     MLD:表示动态MLD
·     PROXY:表示MLD代理
·     STATIC:表示静态MLD
Querier state
接口的查询器状态:
·     Querier:表示接口为MLD查询器
·     Non-querier:表示接口不是MLD查询器
Join/Prune state
接口的加入/剪枝状态:
·     NI:表示默认状态
·     Join:表示处于MLD加入的状态
·     Prune:表示处于MLD剪枝的状态
display mld ssm-mapping命令用来显示MLD SSM Mapping规则。
display mld ssm-mapping ipv6-group-address
# 显示公网实例中IPv6组播组FF3E::101对应的MLD SSM Mapping规则。
<Sysname> display mld ssm-mapping ff3e::101
 Group: FF3E::101
 Source list:
        1::1
        1::2
        10::1
        100::10
表1-11 display mld ssm-mapping命令显示信息描述表
Group
IPv6组播组地址
Source list
IPv6组播源地址列表
display mld user-authorization命令用来显示MLD用户的授权信息。
display mld user-authorization [ access-type { ipoe | portal | ppp } ] [ access-interface interface-type interface-number | interface interface-type interface-number ] [ active-user ]
access-type:显示指定接入类型的IPv6组播用户的授权信息。
ipoe:显示IPoE接入类型的IPv6组播用户的授权信息。
portal:显示Portal接入类型的IPv6组播用户的授权信息。
ppp:显示PPP接入类型的IPv6组播用户的授权信息。
access-interface interface-type interface-number:显示指定接口接入的IPv6组播用户的授权信息。
interface interface-type interface-number:显示指定用户接口上的信息。
active-user:显示有IPv6组播组加入的接入用户的信息。
如果未指定任何参数,将显示所有MLD用户的授权信息。
# 显示所有MLD用户的授权信息。
<Sysname> display mld user-authorization
 Authorized users in total: 3
   User name: user1@isp1
   Access type: PPP
   Interface: Multicast-UA2
   Access interface: bas-interface1 (GigabitEthernet3/1/1.2)
   User address: 102::1
   User ID: 0x20000002 (Session ID 0x1)
   Maximum allowed programs: 10
   User profile: profile1
   Authorized program list:
     FF03::101
   User name: user2
   Access type: IPoE
   Interface: Multicast-UA0
   Access interface: GigabitEthernet3/1/1.1
   VLAN ID: 100
   Second VLAN ID: 10
   User address: 101::1
   User ID: 0x40000001 (VLAN ID 100, Second VLAN ID 10)
     FF03::101
     FF03::102
     FF03::103
   User name: user3
   Access type: Portal
   Interface: Multicast-UA1
   User address: 103::1
   User ID: 0x10000001
     FF03::101
     FF03::103
# 显示有IPv6组播组加入的MLD用户的授权信息。
<Sysname> display mld user-authorization active-user
 Active users in total: 1
   Access type: PPP
   Maximum allowed programs: 4
     FF03::101
# 显示PPP接入类型的MLD用户的授权信息。
<Sysname> display mld user-authorization access-type ppp
 Authorized users in total: 2
 Matching users in total: 1
   Access type: PPP
     FF03::101
# 显示有IPv6组播组加入的PPP接入类型的MLD用户授权信息。
<Sysname> display mld user-authorization access-type ppp active-user
   Access type: PPP
     FF03::101
表1-12 display mld user-authorization命令显示信息描述表
接入用户总数
User name
用户名
符合配置条件的MLD用户数量
Access type
用户接入的方式:
·     IPoE:表示IPoE方式
·     Portal:表示Portal方式
·     PPP:表示PPP方式
IPv6组播用户接口
Access interface
用户接入的实际接口
User address
用户地址。如果未获取到用户地址,则不显示本字段
Gateway address
用户网关地址。如果未获取到网关地址,则不显示本字段
User MAC address
用户MAC地址,如果未获取到MAC地址,则不显示本字段
User ID
用户ID
Leased user ID
专线用户ID。如果不是专线用户,则不显示本字段
Session ID
会话ID。如果不是PPPoE用户,则不显示本字段
VLAN ID
用户带VLAN Tag接入时所携带的第一层(或唯一一层)VLAN编号。如果没有则不显示本字段
Second VLAN ID
用户带VLAN Tag接入时所携带的第二层VLAN编号。如果没有则不显示本字段
PVC ID
ATM接入时所携带的PVC号。如果不是ATM接入,则不显示本字段
允许用户加入IPv6组播组的最大数量
User profile
用户授权的User Profile名称,用户可加入该User Profile下通过mld access-policy命令所配置接入策略中的IPv6组播组
用户授权加入的IPv6组播组列表
有IPv6组播组加入的接入用户总数量
last-listener-query-count命令用来全局配置MLD最后组成员查询次数。
undo last-listener-query-count命令用来恢复缺省情况。
last-listener-query-count count
MLD最后组成员查询次数等于MLD查询器的健壮系数。
MLD视图
count:指定MLD最后组成员查询次数,取值范围为1~255。
本命令与mld last-listener-query-count命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD最后组成员查询次数为6次。
[Sysname] mld
[Sysname-mld] last-listener-query-count 6
·     mld last-listener-query-count
last-listener-query-interval命令用来全局配置MLD最后组成员查询间隔。
undo last-listener-query-interval命令用来恢复缺省情况。
MLD最后组成员查询间隔为1秒。
MLD视图
interval:指定MLD最后组成员的查询间隔,取值范围为1~25,单位为秒。
本命令与mld last-listener-query-interval命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD最后组成员查询间隔为6秒。
[Sysname] mld
[Sysname-mld] last-listener-query-interval 6
·     mld last-listener-query-interval
max-response-time命令用来全局配置MLD普遍组查询报文的最大响应时间。
undo max-response-time命令用来恢复缺省情况。
max-response-time time
MLD普遍组查询报文的最大响应时间为10秒。
MLD视图
time:指定MLD普遍组查询报文的最大响应时间,取值范围为1~3174,单位为秒。
本命令与mld max-response-time命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD普遍组查询报文的最大响应时间为25秒。
[Sysname] mld
[Sysname-mld] max-response-time 25
·     mld max-response-time
1.1.14  mld
mld命令用来进入MLD视图。
undo mld命令用来清除MLD视图下的所有配置。
mld
undo mld
# 进入公网实例的MLD视图。
[Sysname] mld
[Sysname-mld]
mld access-policy命令用来配置MLD用户的接入策略。
undo mld access-policy命令用来删除MLD用户的接入策略。
mld access-policy ipv6-acl-number
undo mld access-policy ipv6-acl-number
不存在MLD用户的接入策略,即MLD用户未被授权加入IPv6组播组。
User-Profile视图
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。MLD用户只能加入该ACL规则所允许的IPv6组播组。当指定的ACL不存在或ACL中未配置有效规则,将过滤掉所有IPv6组播组。
通过多次执行本命令可以配置多条MLD用户接入策略,用户发送的MLD成员关系报告报文只需匹配其中一条就允许通过。
对于IPv6基本ACL,该ACL规则中的source参数用来指定MLD报文中的IPv6组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
对于IPv6高级ACL,该ACL规则中的source参数用来指定MLD报文中的IPV6组播源地址(对于MLDv1报文和未携带组播源地址的IS_EX/TO_EX类型的MLDv2报文,视其IPv6组播源地址为0::0)范围,destination参数用来指定IPv6组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
若ACL中指定了vpn-instance参数则该条规则不生效。
多次执行本命令,最后一次执行的命令生效。
# 在名为abc的User Profile下配置只允许MLD用户加入IPv6组播组FF03::101。
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source ff03::101 128
[Sysname] user-profile abc
[Sysname-user-profile-abc] mld access-policy 2000
mld attack-suppression per-interface aging-time命令用来配置基于接口的MLD攻击检测表项老化时间。
undo mld attack-suppression per-interface aging-time命令用来恢复缺省情况。
mld attack-suppression per-interface aging-time time
基于接口的MLD攻击检测表项老化时间为30秒。
time:基于接口的MLD攻击检测表项老化时间,取值范围为1~65535,单位为秒。
当某个接口上的MLD攻击检测表项到达老化时间后,设备会检测该表项对应的MLD报文是否为攻击报文:
·     如果是攻击报文,则继续对接口上的MLD报文限速。
·     如果不是攻击报文,则解除该接口上的MLD报文限速。该表项老化后,设备会重新统计该接口上对应的MLD报文数,根据配置的MLD攻击检测周期和阈值,再次判断该接口上的MLD报文是否为攻击报文。
只有配置mld attack-suppression per-interface enable命令开启了MLD攻击抑制功能,本功能才生效。
# 配置基于接口的MLD攻击检测表项老化时间为60秒。
[Sysname] mld attack-suppression per-interface aging-time 60
mld attack-suppression per-interface check-interval命令用来配置基于接口的MLD攻击检测周期。
undo mld attack-suppression per-interface check-interval命令用来恢复缺省情况。
mld attack-suppression per-interface check-interval interval
基于接口的MLD攻击检测周期为30秒。
interval:基于接口的MLD攻击检测周期,取值范围为1~255,单位为秒。
只有配置mld attack-suppression per-interface enable命令开启了基于接口的MLD攻击抑制功能,本功能才生效。
# 配置基于接口的MLD攻击检测周期为10秒。
[Sysname] mld attack-suppression per-interface check-interval 10
mld attack-suppression per-interface enable命令用来使能基于接口的MLD攻击抑制功能。
undo mld attack-suppression per-interface enable命令用来关闭基于接口的MLD攻击抑制功能。
基于接口的MLD攻击抑制功能处于关闭状态。
配置基于接口的MLD攻击抑制功能后,设备会在对应接口下统计收到的MLD报文数,并创建攻击检测表项。当设备在指定的MLD攻击检测周期内,在某个接口下收到的MLD报文数超过配置的攻击抑制阈值,则认为该接口受到MLD报文的攻击,此时设备会限制该接口的MLD报文上送CPU的速率。
在全局使能MLD Snooping的情况下,仅对三层以太网接口和以太网子接口生效,此时VLAN接口和二层接口(例如二层聚合接口)收到MLD报文后,会由二层组播进行处理,三层组播的MLD攻击抑制功能不再生效。
# 开启基于接口的MLD攻击抑制功能。
[Sysname] mld attack-suppression per-interface enable
mld attack-suppression per-interface threshold命令用来配置基于接口的MLD攻击抑制阈值。
undo mld attack-suppression per-interface threshold命令用来恢复缺省情况。
mld attack-suppression per-interface threshold threshold-value
基于接口的MLD攻击抑制阈值为6000。
threshold-value:基于接口的MLD攻击抑制阈值,即攻击检测周期内可接收的MLD报文最大个数,取值范围为1~4294967295。
在指定攻击检测周期内,如果某个接口下收到的MLD报文数量超过配置的攻击抑制阈值,则认为该接口受到了攻击。
# 配置基于接口的MLD攻击抑制阈值为300。
[Sysname] mld attack-suppression per-interface threshold 300
mld attack-suppression source-mac aging-time命令用来配置基于源MAC地址的MLD攻击检测表项老化时间。
undo mld attack-suppression source-mac aging-time命令用来恢复缺省情况。
mld attack-suppression source-mac aging-time time
基于源MAC地址的MLD攻击检测表项老化时间为30秒。
time:基于源MAC地址的MLD攻击检测表项老化时间,取值范围为1~65535,单位为秒。
当某个源MAC地址对应的MLD攻击检测表项到达老化时间后,设备会检测该表项对应的MLD报文是否为攻击报文:
·     如果是攻击报文,则丢弃该源MAC地址对应的MLD报文。
·     如果不是攻击报文,则继续接收该源MAC地址对应的MLD报文。该表项老化后,设备会重新统计该源MAC地址对应的MLD报文数,根据配置的MLD攻击检测周期和阈值,再次判断该源MAC地址的对应的MLD报文是否为攻击报文。
只有配置mld attack-suppression source-mac enable命令开启了MLD攻击抑制功能,本功能才生效。
# 配置基于源MAC地址的MLD攻击检测表项老化时间为60秒。
[Sysname] mld attack-suppression source-mac aging-time 60
mld attack-suppression source-mac check-interval命令用来配置基于源MAC地址的MLD攻击检测周期。
undo mld attack-suppression source-mac check-interval命令用来恢复缺省情况。
mld attack-suppression source-mac check-interval interval
基于源MAC地址的MLD攻击检测周期为30秒。
interval:基于源MAC地址的MLD攻击检测周期,取值范围为1~255,单位为秒。
只有配置mld attack-suppression source-mac enable命令开启了基于源MAC地址的MLD攻击抑制功能,本功能才生效。
# 配置基于源MAC地址的MLD攻击检测周期为10秒。
[Sysname] mld attack-suppression source-mac check-interval 10
mld attack-suppression source-mac enable命令用来使能基于源MAC地址的MLD攻击抑制功能。
undo mld attack-suppression source-mac enable命令用来关闭基于源MAC地址的MLD攻击抑制功能。
基于源MAC地址的MLD攻击抑制功能处于关闭状态。
配置基于源MAC地址的MLD攻击抑制功能后,设备会根据MLD报文中的源MAC地址统计收到的MLD报文数,并创建攻击检测表项。当设备在指定的攻击检测周期内,收到某个源MAC地址对应的MLD报文数超过配置的攻击抑制阈值,则认为设备受到了该源MAC地址的MLD报文的攻击,此时设备会丢弃来自该MAC地址的MLD报文,避免因为处理大量MLD报文占用过多CPU资源,导致其他正常MLD报文无法及时得到处理。
# 使能基于源MAC地址的MLD攻击抑制功能。
[Sysname] mld attack-suppression source-mac enable
mld attack-suppression source-mac threshold命令用来配置基于源MAC地址的MLD攻击抑制阈值。
undo mld attack-suppression source-mac threshold命令用来恢复缺省情况。
mld attack-suppression source-mac threshold threshold-value
基于源MAC地址的MLD攻击抑制阈值为6000。
threshold-value:基于源MAC地址的MLD攻击抑制阈值,即攻击检测周期内可接收的MLD报文最大个数,取值范围为1~4294967295。
在指定攻击检测周期内,如果收到指定源MAC地址的MLD报文数量超过配置的攻击抑制阈值,则认为来自该源MAC地址的MLD报文为攻击报文。
# 配置基于源MAC地址的MLD攻击抑制阈值为300。
[Sysname] mld attack-suppression source-mac threshold 300
mld authorization-enable命令用来开启IPv6可控组播功能。
undo mld authorization-enable命令用来关闭IPv6可控组播功能。
IPv6可控组播功能处于关闭状态。
三层以太网接口视图/三层以太网子接口视图
三层聚合接口视图/三层聚合子接口视图
VT接口视图
本命令只对本地上线用户生效,非本地上线用户、或非上线用户不受此控制。
# 在接口GigabitEthernet3/1/1上开启IPv6可控组播功能。
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] mld authorization-enable
1.1.25  mld enable
mld enable命令用来在接口上使能MLD。
undo mld enable命令用来在接口上关闭MLD。
mld enable
undo mld enable
接口上的MLD处于关闭状态。
只有在相应实例中先使能了IPv6组播路由,本命令才能生效。
只有在接口上使能了MLD,在该接口上所做的MLD配置才能生效。
# 使能公网实例中的IPv6组播路由,并在接口GigabitEthernet3/1/1上使能MLD。
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname-GigabitEthernet3/1/1] mld enable
·     ipv6 multicast routing(IP组播命令参考/IPv6组播路由与转发)
mld fast-leave命令用来在接口上开启IPv6组播组成员快速离开功能。
undo mld fast-leave命令用来在接口上关闭IPv6组播组成员快速离开功能。
mld fast-leave [ group-policy ipv6-acl-number ]
undo mld fast-leave
IPv6组播组成员快速离开功能处于关闭状态,即MLD查询器在收到主机发送的MLD离开组报文后将发送MLD特定组查询报文或MLD特定源组查询报文,而不会直接向上游发送离开通告。
ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。如果指定了本参数,快速离开功能将只为该ACL规则所允许的IPv6组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则快速离开功能将为所有IPv6组播组服务。
开启了IPv6组播组成员快速离开功能之后,当MLD查询器收到来自主机的离开组报文时,不再发送MLD特定组查询报文或MLD特定源组查询报文。
对于IPv6基本ACL,该ACL规则中的source参数用来指定IPv6组播组的范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
# 在接口GigabitEthernet3/1/1上开启IPv6组播组成员快速离开功能。
[Sysname-GigabitEthernet3/1/1] mld fast-leave
mld group-policy命令用来在接口上配置IPv6组播组过滤器,以限定该接口下的主机所能加入的IPv6组播组。
undo mld group-policy命令用来在接口上删除IPv6组播组过滤器。
mld group-policy ipv6-acl-number [ version-number ]
接口上不存在IPv6组播组过滤器,即该接口下的主机可以加入任意IPv6组播组。
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。主机只能加入该ACL规则所允许的IPv6组播组。当指定的ACL不存在或ACL中未配置有效规则,将过滤掉所有IPv6组播组。
version-number:指定MLD的版本号,取值范围为1~2。缺省情况下,系统同时支持对MLDv1和MLDv2报告报文的过滤。
由于本命令只能过滤MLD报文,因此无法对接口静态加入IPv6组播组或组播源组进行限制。
对于IPv6高级ACL,该ACL规则中的source参数用来指定MLD报文中的组播源地址(对于MLDv1/v2报文和未携带组播源地址的IS_EX/TO_EX类型的MLDv3报文,视其IPv6组播源地址为0.0.0.0)范围,destination参数用来指定IPv6组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 限定接口GigabitEthernet3/1/1下的主机只能加入IPv6组播组FF03::101。
[Sysname] acl ipv6 basic 2005
[Sysname-acl-ipv6-basic-2005] rule permit source ff03::101 128
[Sysname-acl-ipv6-basic-2005] quit
[Sysname-GigabitEthernet3/1/1] mld group-policy 2005
mld join-by-session命令用来配置按会话记录用户加入的IPv6组播组。
undo mld join-by-session命令用来恢复缺省情况。
mld join-by-session [ mode { both | bras | non-bras } ]
按接口记录用户加入的IPv6组播组。
三层聚合接口视图/三层聚合子接口视图
mode:指定按会话记录的用户的接入类型,即对于指定类型的接入用户,按会话记录该类用户加入的IPv6组播组。如果没有指定此参数,则所有类型的用户均按会话记录加入的IPv6组播组。
both:BRAS(Broadband Remote Access Server,宽带远程接入服务器)用户和非BRAS用户均按会话记录用户加入的IPv6组播组。
bras:仅BRAS用户(目前MLD支持IPoE、PPP和Portal三种类型的BRAS用户)按会话记录加入的IPv6组播组。
non-bras:仅非BRAS用户(无需接入认证的用户)按会话记录加入的IPv6组播组。
当按接口记录用户加入的IPv6组播组时,设备只会向物理接口发送一份IPv6组播报文;当按会话记录用户加入的IPv6组播组时,设备会向接口下的每位用户分别发送一份IPv6组播报文。
mld join-by-session命令与mld user-vlan-aggregation dot1q命令互斥,不允许同时配置。
# 在接口GigabitEthernet3/1/1上配置所有类型的用户均按会话记录加入的IPv6组播组。
[Sysname-GigabitEthernet3/1/1] mld join-by-session
mld last-listener-query-count命令用来在接口上配置MLD最后组成员查询次数。
undo mld last-listener-query-count命令用来恢复缺省情况。
mld last-listener-query-count count
本命令与last-listener-query-count命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD最后组成员查询次数为6次。
[Sysname-GigabitEthernet3/1/1] mld last-listener-query-count 6
·     last-listener-query-count (MLD view)
mld last-listener-query-interval命令用来在接口上配置MLD最后组成员查询间隔。
undo mld last-listener-query-interval命令用来恢复缺省情况。
mld last-listener-query-interval interval
MLD最后组成员查询间隔为1秒。
本命令与last-listener-query-interval命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD最后组成员查询间隔为6秒。
[Sysname-GigabitEthernet3/1/1] mld last-listener-query-interval 6
·     last-listener-query-interval (MLD view)
mld max-response-time命令用来在接口上配置MLD普遍组查询报文的最大响应时间。
undo mld max-response-time命令用来恢复缺省情况。
mld max-response-time time
本命令与max-response-time命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD普遍组查询报文的最大响应时间为25秒。
[Sysname-GigabitEthernet3/1/1] mld max-response-time 25
·     max-response-time (MLD view)
mld non-stop-routing命令用来开启MLD协议的NSR功能。
undo mld non-stop-routing命令用来关闭MLD协议的NSR功能。
MLD协议的NSR功能处于关闭状态。
# 开启MLD协议的NSR功能。
[Sysname] mld non-stop-routing
mld other-querier-present-timeout命令用来在接口上配置MLD其它查询器的存在时间。
undo mld other-querier-present-timeout命令用来恢复缺省情况。
mld other-querier-present-timeout time
MLD其它查询器的存在时间=MLD普遍组查询报文的发送间隔×MLD查询器的健壮系数+MLD普遍组查询的最大响应时间÷2。
time:指定MLD其它查询器的存在时间,取值范围为1~31744,单位为秒。
本命令与other-querier-present-timeout命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD其它查询器的存在时间为125秒。
[Sysname-GigabitEthernet3/1/1] mld other-querier-present-timeout 125
·     other-querier-present-timeout (MLD view)
mld proxy enable命令用来在接口上开启MLD代理功能。
undo mld proxy enable命令用来关闭接口上的MLD代理功能。
mld proxy enable
接口上的MLD代理功能处于关闭状态。
# 使能公网实例中的Ipv6组播路由,并在接口GigabitEthernet3/1/1上开启MLD代理功能。
[Sysname-GigabitEthernet3/1/1] mld proxy enable
mld proxy forwarding命令用来开启非查询器转发功能。
undo mld proxy forwarding命令用来关闭非查询器转发功能。
非查询器转发功能处于关闭状态。
IPv6组播数据通常只被查询器转发,非查询器不具备IPv6组播转发能力,这样可避免IPv6组播数据被重复转发。但如果MLD代理设备的路由器接口未能当选查询器,应在该接口上开启非查询器转发功能,否则下游主机将无法收到IPv6组播数据。
# 在MLD代理设备的路由器接口GigabitEthernet3/1/1上开启非查询器转发功能。
[Sysname-GigabitEthernet3/1/1] mld proxy forwarding
mld query-interval命令用来在接口上配置MLD普遍组查询报文的发送间隔。
undo mld query-interval命令用来恢复缺省情况。
mld query-interval interval
MLD普遍组查询报文的发送间隔为125秒。
interval:指定MLD普遍组查询报文的发送间隔,取值范围为1~31744,单位为秒。
本命令与query-interval命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD普遍组查询报文的发送间隔为60秒。
[Sysname-GigabitEthernet3/1/1] mld query-interval 60
·     query-interval (MLD view)
mld robust-count命令用来在接口上配置MLD查询器的健壮系数。
undo mld robust-count命令用来恢复缺省情况。
mld robust-count count
MLD查询器的健壮系数为2。
count:指定MLD查询器的健壮系数,取值范围为1~255。
MLD查询器的健壮系数是为了弥补可能发生的网络丢包而设置的报文重传次数,健壮系数越大,MLD查询器就越“健壮”,但是组播组超时所需的时间也就越长。
本命令与robust-count命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD查询器的健壮系数为5。
[Sysname-GigabitEthernet3/1/1] mld robust-count 5
·     robust-count (MLD view)
mld startup-query-count命令用来在接口上配置MLD查询器的启动查询次数。
undo mld startup-query-count命令用来恢复缺省情况。
mld startup-query-count count
MLD查询器的启动查询次数等于MLD查询器的健壮系数。
count:指定MLD查询器的启动查询次数,取值范围为1~255。
本命令与startup-query-count命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD查询器的启动查询次数为5次。
[Sysname-GigabitEthernet3/1/1] mld startup-query-count 5
·     startup-query-count (MLD view)
mld startup-query-interval命令用来在接口上配置MLD查询器的启动查询间隔。
undo mld startup-query-interval命令用来恢复缺省情况。
mld startup-query-interval interval
MLD查询器的启动查询间隔为MLD普遍组查询报文发送间隔的1/4。
interval:指定MLD查询器的启动查询间隔,取值范围为1~31744,单位为秒。
本命令与startup-query-interval命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在接口GigabitEthernet3/1/1上配置MLD查询器的启动查询间隔为100秒。
[Sysname-GigabitEthernet3/1/1] mld startup-query-interval 100
·     startup-query-interval (MLD view)
mld static-group命令用来配置接口静态加入IPv6组播组或组播源组。
undo mld static-group命令用来恢复缺省情况。
mld static-group ipv6-group-address [ inc-step-mask group-mask-length number group-number ] [ source ipv6-source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ]
undo mld static-group { all | ipv6-group-address [ inc-step-mask group-mask-length number group-number ] [ source ipv6-source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ] }
接口没有以静态方式加入IPv6组播组或组播源组。
ipv6-group-address:指定IPv6组播组地址,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。在批量配置方式中为组地址序列的起始地址。
inc-step-mask group-mask-length:指定批量配置方式中的组地址步长掩码长度。group-mask-length表示组地址步长掩码长度,为整数格式,取值范围是9~128。
group-number:指定批量配置方式中的组地址个数。为整数格式,取值范围是2~512。
ipv6-source-address:指定组播源的IPv6地址。如果未指定本参数,表示针对所有组播源。
dot1q vid vlan-list:指定封装的第一层VLAN Tag。vlan-list为VLAN列表,表示一或多个第一层VLAN Tag,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。本参数只在三层以太网子接口视图和三层聚合子接口视图下支持。
dot1q vid vlan-id second-dot1q vlan-list:指定封装的第一层和第二层VLAN Tag。vlan-id表示第一层VLAN Tag,取值范围为1~4094;vlan-list为VLAN列表,表示一或多个第二层VLAN Tag,表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。本参数只在三层以太网子接口视图和三层聚合子接口视图下支持。
all:删除此接口加入的所有静态IPv6组播组。
如果指定的IPv6组播组地址在SSM组地址范围内,则必须同时指定IPv6组播源的地址,否则将不会生成IPv6组播路由表项用于指导组播转发;如果指定的IPv6组播组地址不在SSM组地址范围内,则无此限制。
指定dot1q vid vlan-id second-dot1q vlan-list时,需要注意:
·     对于同一个IPv6组播组或IPv6组播源组,不带VLAN封装、带一层VLAN封装和带两层VLAN封装的静态加入配置两两互斥,不允许同时配置。
·     配置不带VLAN封装的静态加入时,如果子接口上没有配置mld join-by-session命令和mld user-vlan-aggregation dot1q命令,才生成IPv6静态组播表项。
·     配置带VLAN封装的静态加入时,如果子接口有相应VLAN用户上线,才生成IPv6静态组播表项;或者子接口上配置了mld user-vlan-aggregation dot1q命令,那么只有二者的VLAN封装相同,才生成IPv6静态组播表项。
通过该命令配置接口静态加入组播组或组播源组时,支持单个配置和批量配置两种方式。需要注意:
·     不同的组播组批量配置,可能存在相同的组播组地址,这种配置的重叠是允许的。
·     删除批量配置的组播组或组播源组时,只可删除某条批量配置中的所有的组播组或组播源组,不可单独删除该条批量配置中的某个具体的组播组或者组播源组。
·     当批量配置的命令除了number group-number不相同,其余参数配置均相同时,后一条配置会覆盖前一条配置,即最后一次执行的命令生效。
# 配置接口GigabitEthernet1/0/1静态加入组播组起始地址为ff03::101,步长掩码长度为128,组地址数量为2的批量组播组,即接口GigabitEthernet1/0/1加入了组地址为ff03::101ff03::102的组播组。
[Sysname-GigabitEthernet1/0/1] mld static-group ff03::101 inc-step-mask 128 number 2
# 配置接口GigabitEthernet1/0/1静态加入组播组起始地址为ff03::101,源地址为2001::101,步长掩码长度为128,组地址数量为2的批量组播组。即接口GigabitEthernet1/0/1静态加入了(2001::101ff03::101)和(2001::101ff03::102)的组播源组。
[Sysname-GigabitEthernet1/0/1] mld static-group ff03::101 inc-step-mask 128 number 2 source 2001::101
# 配置子接口GigabitEthernet1/0/1.1静态组播组起始地址为ff03::101,步长掩码长度为128,组地址数量为2的批量组播组,并指定VLAN Tag
[Sysname] interface GigabitEthernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] mld static-group ff03::101 inc-step-mask 128 number 2 dot1q vid 10
mld user-vlan-aggregation dot1q命令用来配置为IPv6组播报文封装的VLAN Tag。
undo mld user-vlan-aggregation dot1q命令用来恢复缺省情况。
mld user-vlan-aggregation dot1q vid vlan-id [ second-dot1q vlan-id ]
不为IPv6组播报文封装VLAN Tag。
三层以太网子接口视图
三层聚合子接口视图
vid vlan-id:指定封装的第一层VLAN Tag,vlan-id的取值范围为1~4094。
second-dot1q vlan-id:指定封装的第二层VLAN Tag,vlan-id的取值范围为1~4094。
# 在子接口GigabitEthernet3/1/1.1上配置为IPv6组播报文封装的第一层VLAN Tag为10,第二层VLAN Tag为20。
[Sysname] interface gigabitethernet 3/1/1.1
[Sysname-GigabitEthernet3/1/1.1] mld user-vlan-aggregation dot1q vid 10 second-dot1q 20
1.1.42  mld version
mld version命令用来在接口上配置MLD的版本。
undo mld version命令用来恢复缺省情况。
mld version version-number
undo mld version
MLD的版本为MLDv1。
version-number:表示MLD的版本号,取值范围为1~2。
由于不同版本MLD协议的报文结构与种类不同,因此需要为同一网段上的所有设备配置相同版本的MLD,否则MLD将不能正常运行。
# 指定接口GigabitEthernet3/1/1使用MLDv2。
[Sysname-GigabitEthernet3/1/1] mld version 2
other-querier-present-timeout命令用来全局配置MLD其它查询器的存在时间。
undo other-querier-present-timeout命令用来恢复缺省情况。
MLD视图
本命令与mld other-querier-present-timeout命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD其它查询器的存在时间为125秒。
[Sysname] mld
[Sysname-mld] other-querier-present-timeout 125
·     mld other-querier-present-timeout
proxy multipath命令用来开启MLD代理的负载分担功能。
undo proxy multipath命令用来关闭MLD代理的负载分担功能。
proxy multipath
MLD代理的负载分担功能处于关闭状态。
MLD视图
当在MLD代理设备的多个接口上开启了MLD代理功能时:如果关闭了MLD代理的负载分担功能,则只有IPv6地址最大的接口会转发IPv6组播流量;如果开启了MLD代理的负载分担功能,则可通过这些接口对IPv6组播流量按组进行负载分担。
# 在公网实例中开启MLD代理的负载分担功能。
[Sysname] mld
[Sysname-mld] proxy multipath
query-interval命令用来全局配置MLD普遍组查询报文的发送间隔。
undo query-interval命令用来恢复缺省情况。
undo query-interval
MLD视图
本命令与mld query-interval命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD普遍组查询报文的时间间隔为60秒。
[Sysname] mld
[Sysname-mld] query-interval 60
·     mld query-interval
reset mld attack-suppression per-interface entry命令用来清除基于接口的MLD攻击检测表项。
(独立运行模式)
reset mld attack-suppression per-interface entry { all | slot slot-number { all | interface interface-type interface-number  } }
reset mld attack-suppression per-interface entry { all | chassis chassis-number slot slot-number { all | interface interface-type interface-number } }
all:前一个all表示清除所有单板上基于接口的MLD攻击检测表项。后一个all表示清除指定单板所有基于接口的MLD攻击检测表项。(独立运行模式)
all:前一个all表示清除所有成员设备上基于接口的MLD攻击检测表项。后一个all表示清除指定单板所有基于接口的MLD攻击检测表项。(IRF模式)
slot slot-number:清除指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
interface interface-type interface-number:清除指定接口上的MLD攻击检测表项,interface-type interface-number表示接口类型和接口编号。
# 清除所有基于接口的MLD攻击检测表项。
<Sysname> reset mld attack-suppression per-interface entry all
·     display mld attack-suppression per-interface entry
reset mld attack-suppression per-interface statistics命令用来清除基于接口的MLD攻击检测相关的MLD报文计数信息。
(独立运行模式)
reset mld attack-suppression per-interface statistics { all | slot slot-number { all | interface interface-type interface-number } }
reset mld attack-suppression per-interface statistics { all | chassis chassis-number slot slot-number { all | interface interface-type interface-number } }
all:前一个all表示清除所有单板上基于接口的MLD攻击检测相关的MLD报文计数信息。后一个all表示清除指定单板所有基于接口的MLD攻击检测相关的MLD报文计数信息。(独立运行模式)
all:前一个all表示清除所有成员设备上基于接口的MLD攻击检测相关的MLD报文计数信息。后一个all表示清除指定单板所有基于接口的MLD攻击检测相关的MLD报文计数信息。(IRF模式)
interface interface-type interface-number:清除指定接口上的MLD攻击检测相关的MLD报文计数信息,interface-type interface-number表示接口类型和接口编号。
本命令清除的统计信息为display mld attack-suppression per-interface entry verbose中的如下字段:CPU receive(CPU收到的报文数)、CPU drop(CPU丢弃的报文数)和Drv drop(驱动丢弃的报文数)。
# 清除所有基于接口的MLD攻击检测相关的MLD报文计数信息。
<Sysname> reset mld attack-suppression per-interface statistics all
reset mld attack-suppression source-mac entry命令用来清除基于源MAC地址的MLD攻击检测表项。
(独立运行模式)
reset mld attack-suppression source-mac entry { all | slot slot-number { all | [ interface interface-type interface-number | mac-address address ] * } }
reset mld attack-suppression source-mac entry { all | chassis chassis-number slot slot-number { all | [ interface interface-type interface-number | mac-address address ] * } }
all:前一个all表示清除所有单板上基于源MAC地址的MLD攻击检测表项。后一个all表示清除指定单板所有接口上基于源MAC地址的MLD攻击检测表项。(独立运行模式)
all:前一个all表示清除所有成员设备上基于源MAC地址的MLD攻击检测表项。后一个all表示清除指定单板所有接口上基于源MAC地址的MLD攻击检测表项。(IRF模式)
interface interface-type interface-number:清除指定接口上基于源MAC地址的MLD攻击检测表项,interface-type interface-number表示接口类型和接口编号。
mac-address address:清除指定源MAC地址对应的MLD攻击检测表项。
# 清除所有基于源MAC地址的MLD攻击检测表项。
<Sysname> reset mld attack-suppression source-mac entry all
·     display mld attack-suppression source-mac entry
reset mld attack-suppression source-mac statistics命令用来清除基于源MAC地址的MLD攻击检测相关的MLD报文计数信息。
(独立运行模式)
reset mld attack-suppression source-mac statistics { all | slot slot-number { all | [ interface interface-type interface-number | mac-address address ] * } }
reset mld attack-suppression source-mac statistics { all | chassis chassis-number slot slot-number { all | [ interface interface-type interface-number | mac-address address ] * } }
all:前一个all表示清除所有单板上基于源MAC地址的MLD攻击检测相关的MLD报文计数信息。后一个all表示清除指定单板所有接口上基于源MAC地址的MLD攻击检测相关的MLD报文计数信息。(独立运行模式)
all:前一个all表示清除所有成员上基于源MAC地址的MLD攻击检测相关的MLD报文计数信息。后一个all表示清除指定单板所有接口上基于源MAC地址的MLD攻击检测相关的MLD报文计数信息。(IRF模式)
interface interface-type interface-number:清除指定接口上基于源MAC地址的MLD攻击检测相关的MLD报文计数信息,interface-type interface-number表示接口类型和接口编号。
mac-address address:清除指定源MAC地址对应的MLD攻击检测相关的MLD报文计数信息。
本命令清除的统计信息为display mld attack-suppression source-mac entry verbose中的如下字段:CPU receive(CPU收到的报文数)、CPU drop(CPU丢弃的报文数)和Drv drop(驱动丢弃的报文数)。
# 清除所有基于源MAC地址的MLD攻击检测相关的MLD报文计数信息。
<Sysname> reset mld attack-suppression source-mac statistics all
reset mld group命令用来清除MLD组播组的动态加入记录。
reset mld group { all | interface interface-type interface-number { all | ipv6-group-address [ prefix-length ] [ ipv6-source-address [ prefix-length ] ] } }
all:前一个all表示清除所有接口上的记录,后一个all表示清除所有组播组的记录。
interface-type interface-number:清除指定接口上的记录。
ipv6-group-address:清除指定IPv6组播组的记录,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
ipv6-source-address:清除指定组播源的记录。如果未指定本参数,将清除所有组播源的记录。
prefix-length:指定组播源或组播组地址的前缀长度。对于组播源地址,其取值范围为0~128,缺省值为128;对于组播组地址,其取值范围为8~128,缺省值为128。
执行本命令可能导致接收者中断IPv6组播信息的接收。
# 清除公网实例所有接口上MLD组播组的动态加入记录。
<Sysname> reset mld group all
# 清除公网实例接口GigabitEthernet3/1/1上所有MLD组播组的动态加入记录。
<Sysname> reset mld group interface gigabitethernet 3/1/1 all
# 清除公网实例接口GigabitEthernet3/1/1上MLD组播组FF03::101:10的动态加入记录。
<Sysname> reset mld group interface gigabitethernet 3/1/1 ff03::101:10
·     display mld group
robust-count命令用来全局配置MLD查询器的健壮系数。
undo robust-count命令用来恢复缺省情况。
robust-count count
undo robust-count
MLD查询器的健壮系数为2。
MLD视图
本命令与mld robust-count命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD查询器的健壮系数为5。
[Sysname] mld
[Sysname-mld] robust-count 5
·     mld robust-count
ssm-mapping命令用来配置MLD SSM Mapping规则。
undo ssm-mapping命令用来删除MLD SSM Mapping规则。
ssm-mapping ipv6-source-address ipv6-acl-number
undo ssm-mapping { ipv6-source-address | all }
不存在MLD SSM Mapping规则。
MLD视图
ipv6-source-address:指定IPv6组播源地址。
ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。通过该ACL规则中的permit语句指定IPv6组播组的范围。当指定的ACL不存在或ACL中未配置有效规则,则表示未指定任何IPv6组播组。
all:删除所有的MLD SSM Mapping规则。
# 在公网实例中添加如下一条MLD SSM Mapping规则:组地址范围为FF3E::/64,对应的源地址为1::1。
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source ff3e:: 64
[Sysname] mld
[Sysname-mld] ssm-mapping 1::1 2001
·     display mld ssm-mapping
startup-query-count命令用来全局配置MLD查询器的启动查询次数。
undo startup-query-count命令用来恢复缺省情况。
MLD视图
本命令与mld startup-query-count命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD查询器的启动查询次数为5次。
[Sysname] mld
[Sysname-mld] startup-query-count 5
·     mld startup-query-count
startup-query-interval命令用来全局配置MLD查询器的启动查询间隔。
undo startup-query-interval命令用来恢复缺省情况。
MLD视图
本命令与mld startup-query-interval命令的功能相同,只是作用范围不同:MLD视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 在公网实例中全局配置MLD查询器的启动查询间隔为100秒。
[Sysname] mld
[Sysname-mld] startup-query-interval 100
·     mld startup-query-interval
